Old 05-02-2006, 03:24 PM   #1
charterali
charterali's Avatar
Urgent help needed, 316i.
Hi, pals I am a new member of this site, saw it nd really liked it as all the bimmerheads r out here. Yesterday, I changed my car's headlight with the help of this site.
I have a E-36, 316i, Model 1993.
I am facing some problems in our part of the world most of the mechanics r not fimiliar with OBD and that kinda stuff, whereas dealer is much more then a robber, so I will appreciate if ya suggest me DIYs.
--- Before warm up ther is an idling disorder.
--- After warm up aswell idling disorder continues.
--- Feul Mixture is rich.
--- At around 3500 RPM in first gear and at around 3000 rpm in rest of the gears it backfires and throws a heavy dump of feul from the back.
--- Accelerator response is not that gudd.
--- Engine feel is just too much underpower.
--- Feul ecconomy isn't tht gudd as it do something lik 5 km/l.
I drive with a light foot and with an average speed of around 60-80 km/hr in city at moderate rpm.
When, I bought this car the acceleration was just too much pathetic, worse then a Fiat or Lada, a friend of my dignosted tht its due to catalyst, so I removed the catalyst and installed a free flow exhaust. After tht perfomance gets better and mileage increases to 5 km/l frm 3 km/l.
Oil filter, Feul filter, air filter all were changed 2000 kms back.
I use High Octane Feul.
I will highly thankful to ya guys if ya help me out with it.
Thnxx..
Old 05-02-2006, 06:05 PM   #2
Rate My Car: 134 / 340
1st off welcome As far as your idle probs - read the knowledge base article (under E36) about cleaning ICV - Idle control valve. While at it check all the vacuum hoses, replace any that are cracked, loose or broken. These two items should get you started in the right direction. Again welcome...
Old 05-02-2006, 10:55 PM   #3
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
2nd thing to say....yes DIY would be much better.
But, if you give up or are having a hard time.....ALWAYS know that you can go to the dealer and have your problems solved....one way or another.
Anywho. I've never heard of a 316i are you somewhere in Europe?
Old 05-02-2006, 11:02 PM   #4
Storamin
Storamin's Avatar
Title: Road Kill
the 316 is very standard in europe. the dealer will rape u.
apart from the 2 things mentioned by c1apton, check out your spark plugs & lamba sensor.
Old 05-03-2006, 06:31 AM   #5
charterali
charterali's Avatar
Thnxx pals for ur replies,
I live out ther in Karachi, Pakistan.
I changed the spark plugs couple of thousand kms back with Bosch 2tip platiniums.
Well, in our part of the world dealer charges around 80$-100$ just for diagnosis, I dont know abt rest of the world as such.
I will clean ma ICV tommorrow and then update ya guys.
Wat is Lamba Sensor?
Thnxx..
Old 05-03-2006, 08:58 AM   #6
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 68 / 340
Your Ride: 1995 M3
First of all, welcome to UB! Have any pictures of your car?
Thnxx..
Actually, there may be something here. I'm not positive, but I'm pretty sure BMWs are only made to work with Bosch Coppers, and I have heard Platinums sometimes cause problems.
Anyone else know about this?
Old 05-03-2006, 09:45 AM   #7
Storamin
Storamin's Avatar
Title: Road Kill
Komodo is right, try out different spark plugs. Our e36's don't like the platinum so well.
Old 06-18-2006, 06:27 AM   #8
charterali
charterali's Avatar
Hi, changed the plugs to OEM. But still the problem continues.
I am planning to replace the O2 Sensor OEM. But unfortunately I don know about the part number. Can anyone help me out with the part no. As I got 316i E-36, 1992-1993.
Thnxx..
Old 06-18-2006, 06:49 AM   #9
Rate My Car: 106 / 340
After a quick search, I believe your O2 sensor (also known outside the US as a Lambda sensor, like Storamin said) will be part #11781734393. But verify this at www.realoem.com. Just enter your vehicle information, and you can look at all the parts in detail. To find your vehicle's production date, look at the sticker on the driver's side door; there should be a month/year of manufacture.
You can also read the OBD fault codes to narrow down the problem. To do this, go to http://www.pelicanparts.com/BMW/tech...de_Reading.htm
Hope this helps, and let us know how things go
Opinion's needed on my Dinan E30 (no 56k) jrhaile Bimmer Showroom 17 03-31-2006 12:33 AM
Carfax Needed!! projal147 United Off Topic  **FOR MEMBERS ONLY** 1 01-30-2006 03:55 PM
if you know anything about mac, read this URGENT Chris Geek Chat 3 09-06-2005 01:07 PM
HELP! Advice On Shocks/Springs set Needed. See Pictures. Are These Good? delmarco E36 6 08-24-2005 09:34 PM
ZKW's coming, hlp needed pls Rooz E36 43 06-18-2005 08:54 PM
