Old 04-27-2006, 04:30 PM   #1
CAPiTUL
CAPiTUL's Avatar
Your Ride: 98 328i
Key wouldn't come out
So I'm shutting my car off. Go to take the key out and the key wouldn't turn back into the lock position all the way so I could get it out. It kind of froze. Turned it back fwd to start the car, then tried shutting it off again. Same thing. After 2 tries the key finally came out. What ya think?
When I was a kid, we had the Atari 2600 with games like Space Invaders and Asteroids! There were no multiple levels or screens, it was just one screen forever! And you could never win. The game just kept getting harder and harder and faster and faster until you died! .... Just like LIFE!
http://www.aftermarketcity.net/forum/
The BEST online directory for your car needs!
ユナイテドビーマーはいいですよ!
Old 04-27-2006, 04:35 PM   #2
Cellardoor
Your Ride: 95 M3
was the wheel cut really hard to one direction? because i know sometimes if the wheel is cut hard to eather side it locks the wheel and the key wont turn all they way, could b the same problem, if it happens again try to turn the wheel more straight and try the key again. Good luck.
-Hutch-
///M Accelerate till you see GOD....then Brake
If life passes you by...............Downshift
Old 04-27-2006, 07:33 PM   #3
Rate My Car: 183 / 337
sounds like it was a bit sticky, maybe some WD40 on the key and insert in in there?(dont take my word for it)
Old 04-27-2006, 07:42 PM   #4
CAPiTUL
CAPiTUL's Avatar
Your Ride: 98 328i
I'll try the wd40 for good measure. actually, the steering column wasn't locked. it was turned slightly. . . only slightly. . . it was weird, i say.
ユナイテドビーマーはいいですよ!
Old 04-28-2006, 10:04 AM   #5
Storamin
Storamin's Avatar
Title: Road Kill
There's something in there that just lets go after time. A lot of people on bimmerforums have had the problem but their key normally won't even move enough to turn the key off.
Old 04-28-2006, 10:57 PM   #6
CAPiTUL
CAPiTUL's Avatar
Your Ride: 98 328i
well then, I suppose I'll ask this question:
Sometimes, as I'm going to start the car, the key turns and keeps turning. It usually takes me by surprise. I think it does it when the key isn't in quite all the way, but i'm not sure as every time it happens it takes me by surprise and I am usually in a rush (so, I never think of stopping to see where the key is positioned). Is that normal?????????
ユナイテドビーマーはいいですよ!
Old 04-29-2006, 07:19 AM   #7
Storamin
Storamin's Avatar
Title: Road Kill
I would say search bimmerforums. There were a few people with that problem. I think it's the lock cyllinder that needs to be replaced?
Old 04-30-2006, 06:25 PM   #8
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
From you saying that your key turns all the way around sometimes thats an obivious giv away that your lock cylinder needs to be replaced.
I actually just ran into the same problem as yours at work on fri. Cust. stats they sometimes cant get the key out of the ignition.
It ended up being a bunch of spilt change in the gear shifter (this car was a E46 with an auto) and the car wasnt going fully into park.
Old 04-30-2006, 07:05 PM   #9
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
Put the car in park.
Twist the key.
Remove key.
Old 04-30-2006, 07:20 PM   #10
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
yeah the lock cylinder seems to be a common issue my mechanic was telling me. Mine was starting to go a while ago, and was super stiff, but if I didn't replace it, it would have just spun around in circles.
Old 04-30-2006, 09:22 PM   #11
Storamin
Storamin's Avatar
Title: Road Kill
So my assumption looks to be correct.
Old 05-01-2006, 01:23 PM   #12
kestrel325is
kestrel325is's Avatar
Your Ride: 1995 325is 5-speed
Just posted this on another topic, but how worn is your key?
My Fiance's car started doing the same thing, but her key was totally worn. Used the spare key, and it works perfectly. Somewhat of a cheaper fix, too.
Old 05-01-2006, 06:10 PM   #13
CAPiTUL
CAPiTUL's Avatar
Your Ride: 98 328i
I'll try using the spare and see if it ever happens. If so, then I'll look into the cylinder. Thanks gang.
ユナイテドビーマーはいいですよ!
Rants on OS X and Installing Gentoo on my Powerbook komodo Geek Chat 18 04-22-2006 03:16 AM
Buying a replacement key. Got questions Numark318i E21, E30 21 02-12-2006 03:29 PM
BMW # Key Rings Dudesky BMW General Discussion 7 01-10-2006 04:48 PM
EWS module faulty? Key reprogram? singring E36 2 01-08-2006 04:37 AM
Driver 's door key lock problem singring E36 2 12-29-2005 06:04 AM
