Old 04-21-2006, 05:55 PM   #1
mullethunter3
mullethunter3's Avatar
Rate My Car: 163 / 337
Question Blower Resistor or something else?!?!?
Okay, so I'm trying to actually fix my poor little car. Here's the question of the week:
My A/C is crazy. It's hot outside. I'm upset.
I use the A/C on 1, 2, or 3 most of the time. Until it shuts off. Then I can only use 4 until 1, 2, or 3 decide to work. The AutoHaus of Clayton (the stealership in the area) says that it is the blower resistor. Are they right? Are they trying to steal from me again?
Just in case you don't know, I have a 1993 with the analog dials.
Your thoughts...
Old 04-21-2006, 06:00 PM   #2
Rate My Car: 84 / 337
Sounds right actually. I had only 0 or 4 working and that was the problem. (Now of course the fan blower doesn't work at all)
Old 04-21-2006, 07:13 PM   #3
tomctx
That would be the first thing I would check, the "resistor pack".
Old 04-21-2006, 07:16 PM   #4
Rate My Car: 183 / 337
haha, that must be a common problem, had the thing go on and off in my car
Old 04-21-2006, 07:24 PM   #5
Rate My Car: 106 / 337
Yep, dealer is right; it is a common issue as the units get older.
Old 04-22-2006, 12:35 PM   #6
mullethunter3
thanks guys.
is there a diy on this or should I write one for the data base?
Old 04-22-2006, 03:43 PM   #7
please write one, although im sure it cant be too complicated(you can figure it out)
Old 04-23-2006, 01:30 PM   #8
Spieluhr
Title: ///M Driven
if it were digital i could point you to the perfect DIY, but im not sure as the analog goes.
Old 04-23-2006, 07:24 PM   #9
Storamin
Storamin's Avatar
Title: Road Kill
who uses AC?
Old 04-24-2006, 05:12 PM   #10
kestrel325is
kestrel325is's Avatar
Your Ride: 1995 325is 5-speed
I don't have a DIY, but this is a pretty easy fix. You gotta take off the driver's side under-dash padding. Then take out that metal knee-bolster.
Get a flashlight, because this part sucks. There is, on the HVAC case (by the firewall) a small brown plug. IIRC, it's square-shaped, and has one 4? prong connecter on it. Unhook the connecter, and give a gentle tug on the brown square. That's the resistor pack. Installation is the reverse of removal.
You might want to give a closer look at that connector, I can't remember off-hand whether there is a clip that holds it to the HVAC case or not.
Hope that helps!
Old 05-12-2006, 12:37 PM   #11
Negrodamus
Negrodamus's Avatar
Rate My Car: 85 / 337
Your Ride: 92 325is
^YESS thanks I needed some instruction on how to replace this
Old 05-13-2006, 02:55 PM   #12
///M Power
Rate My Car: 25 / 337
Your Ride: 95 m3 turbo
Originally Posted by Storamin
who uses AC?
Word. You dont need AC in St. Louis. If you dont like the st louis summer weather, wait 15 minutes and itll probably begin to thunderstorm!
Old 05-13-2006, 04:16 PM   #13
mullethunter3
I'll be writing a DIY on this as the part comes in Wed. or Thurs.
Old 05-16-2006, 11:48 AM   #14
Negrodamus
Negrodamus's Avatar
Your Ride: 92 325is
Theres no clip holding it in at all just give it a slight tug once you remove the harness and then it will pop out and yes using a good amount of light helps out alot. I removed the plastic knee bolster as well as the metal foam one as well so I could see it and whoalaa my a/c is working on all settings again.
Old 05-16-2006, 12:03 PM   #15
Storamin
Storamin's Avatar
Title: Road Kill
i spent a month in MO last summer and the man speaks truth!
Leaf Blower mod doughboyea Video and other Multimedia 6 02-26-2006 10:15 AM
blower motor elbiera 7 Series (E23, E32, E38, E65, E66) 2 10-12-2005 07:58 AM
Replacing A/C Blower Motor Bimmer-junkey E36 2 07-27-2005 02:53 PM
