Old 04-19-2006, 04:20 AM   #1
jessicias
Ok, So I'm new to the game...
I just bought a 1992 325i. This is my first BMW (but hopefully not my last!!) are there any little tricks of the trade, quriks about this model that I should know about?
~Jess
Old 04-19-2006, 05:01 AM   #2
Spieluhr
Title: ///M Driven
congrats on buying the car. first off, next time just check in with a forum like this before you buy a car, that way you can have the car inspected and find out what common problems there are, that your mechanic can look for.
as far as your particular model goes, I would inspect the cooling system top to bottom, Check out the suspension components (bushings, shocks, etc.), check all fluids.
did the car come with any repair/maintenance logs?
Old 04-19-2006, 05:49 AM   #3
Rate My Car: 106 / 337
Welcome
Yep, like Spieluhr said, cooling system and suspension, you probably have a good amount of mileage on that '92. I have the same year, with 147k. If you have no service history or records, a new water pump is an absolute must. Then have the rest of the cooling system tested, flush and refill with new coolant. Summer is around the corner, and you'll want to do some preventative maintenance now
Old 04-19-2006, 06:00 AM   #4
Rate My Car: 137 / 337
Welcome. You should do a complete maintenance on it (providing you don't have records) just to give you a level perspective on the maintenance schedule and also to check for any possible future issues or problems. AKA "Peace of mind"
Old 04-19-2006, 08:11 AM   #5
POS_BMW
Rate My Car: 299 / 337
Welcome,
you should also check the fuel lines, make sure on a cold start its not leaking fuel (from the bottom of the car), if it is its a very easy fix on just repairing on one of the fuel lines, I know BMW dealerships sell a kit, but you could probaby do it yourself.
Also check the steering system, such as Tierods, Control arms, ball sockets. The way you check it is lift up the total front end of the car then have someone hold the steering wheel straight then shake the wheel left to right, then up and down, there should be "SLIGHT" movement, but if there is anything more than slight, you need to have it inspected by an alighment specialist.
I have a 93 325i and I had to replace my control arm due to a faulty lower ball joint.
Welcome!
VROOOOOOOOOOOOM!
Old 04-19-2006, 10:08 AM   #6
scrichy84
Your Ride: 1995 325i (Sold), 2004 Tacoma (Sold), 2006 Jetta TDI, 2007 Rabbit
There is also a great post that actually hooked me onto the forum.
http://www.unitedbimmer.com/forums/t...ghlight=faults
It's great info on the common problems of the e36's.
Scrichy84: 1995 325i sold, 2004 Tacoma sold, 2006 TDi Jetta, 2007 Rabbit
Old 04-19-2006, 12:08 PM   #7
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
Welcome to the site, yea as these guys have said you probably want to get it checked out. People here are pretty knowledgable and helpfull so if you have any issues hopefully someone here can help you out.
Old 04-19-2006, 12:52 PM   #8
EuroStyle
Your Ride: 92 325i
Welcome to the forums
non-vanos FTW!
-Matt
Old 04-19-2006, 03:02 PM   #9
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
Welcome to UB!
Old 04-19-2006, 03:10 PM   #10
Storamin
Storamin's Avatar
Title: Road Kill
A neat thing you might not know --
Leave your windows down and lock the door with the key and keep the key in the locked position. The windows will start to come up.
Old 04-19-2006, 05:27 PM   #11
I just ran all the way out to the car to try it, and it doesn't work
I was all excited 'coz I've had this car for over a year now, and didn't know that. Is it only for certain years, or is mine broken, or what??
Old 04-19-2006, 05:31 PM   #12
Rate My Car: 84 / 337
Welcome to UB.C Nice car!
Old 04-19-2006, 05:33 PM   #13
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
Welcome to the gang
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 04-19-2006, 05:46 PM   #14
///M Power
Rate My Car: 25 / 337
Your Ride: 95 m3 turbo
One thing you should do immediately is replace the water pump. The factory pump has a plastic impellor blade in it that tends to fail. Take it to your mechanic and get one put in with a metal impellor blade. If that water pump fails you could be looking at an overheated motor.
Old 04-19-2006, 05:56 PM   #15
komodo
komodo's Avatar
Your Ride: 1995 M3
I'm not sure what years it's on... but I know it works with my 97 328i and my 95 M3... in addition to my friend's 2003 e46 325i.
You put the key in the door, turn it to the lock position, and hold it for about 3-5 seconds. First the back windows (on a 4 door) roll up completely, then the front windows roll up, then the sunroof closes... all with you standing outside the car.
F&@k this game! Hoppy Rant Forum 14 04-02-2006 01:18 PM
San Andreas given AO rating and pulled from shelves komodo United Off Topic  **FOR MEMBERS ONLY** 14 08-11-2005 04:08 PM
Is Every One Giving Up On The Werewolf Game? craig United Off Topic  **FOR MEMBERS ONLY** 22 07-20-2005 08:37 PM
For those hip hop fans out there G-unit and Game Beef guywithblack88e30 United Off Topic  **FOR MEMBERS ONLY** 5 06-26-2005 02:59 AM
