I just ran all the way out to the car to try it, and it doesn't work
I was all excited 'coz I've had this car for over a year now, and didn't know that. Is it only for certain years, or is mine broken, or what??
"Dski", go all the way to the "double lock" position on your car & hold it. Mine does it with the door lock remote too.
Your Ride: 92 325i
Originally Posted by ///M Power
One thing you should do immediately is replace the water pump. The factory pump has a plastic impellor blade in it that tends to fail. Take it to your mechanic and get one put in with a metal impellor blade. If that water pump fails you could be looking at an overheated motor.
And while you are having that done, include the fan delete from understeer.com. You don't need the aluminum thermostat housing because the 92's came with them.
I <3 the MOD BUG
-Matt
Your Ride: 1997 Camry CE
And lastly, make sure you don't have any battery problems. Try and find out when the last time it got a new battery.
Buuut, if you're having problems, just take it to your local dealership and they'll take good care of you.
They'll tell you the history, problems, and things you need to tune up the bimmer.
Btw, some questions....
How many miles does it have?
What color is it?
Is it a manual?
AND, lastly....do you have some pictures?
Nope, doesn't work. Tried it on both doors, even on the trunk lock. I wish I knew what I was looking for to find out if this car is supposed to do that. Oh well . . .
May. . . borderline to the changes in 6/92. I never know what was what in this car, like the struts require the ones for 6/92 on up, learned that the hard way
Your Ride: 92 325i
Hey, I saw you on cardomain, (name is 1bmw325i). I left you a message because you didn't have a page to view. Let me know when ever you get it up and running.
And...PICS or
-Matt
the trunk lock does not activate the windows, or the sunroof, or the convertible top. The door windows will and in my case also close my top but it does take about 30 seconds so you have to stand there with the key turned to get it to close. When I upgrade the alarm it should also close my top.
Your Ride: 1995 BMW
I tried it on my 95 coupe the windows close but the drivers side window starts to go up but then stops aobut 3/4 of the way and it only works with door lock and not the remote Can you change these settings some where?
