Old 04-09-2006, 11:57 PM   #16
B_w.
Rate My Car: 65 / 337
Your Ride: turbo e36
i would be worried about software with s50 cams. the only software i know of is for s52 cams
Old 04-10-2006, 08:39 AM   #17
///Menace328i
Your Ride: 1998 328i
Originally Posted by Tochenzo
they are like .2 more aggressive but they fit fine
Sooo I CAM DO IT!
Redefining Ballerism!
Old 04-10-2006, 10:35 AM   #18
drz
Title: local dumbass
Rate My Car: 32 / 337
Your Ride: E36 2.8i
How much does somethihng like this cost? Would you do it on an m52 with 190k on the odo?
Old 04-10-2006, 10:46 AM   #19
///Menace328i
well I'm doing the whole thing myself... all I'm paying for is the parts. And I'll tell you what I got 180,xxx + but then again I'm doing some serious work since I've overheated and my alternator was about to go....
new OE 140 amp alternator
new radiator
UUC pullies
S50 Cams
new head gasket(s)
Fuel injectors cleaned, balanced and calibrated
my wife gonna kill me when she sees how much I've spent... then I'll show her how much I've saved in labor... then I'll go spend what I've saved . Imma bout to reach the $1k mark give or take $100.
I was going to do a M50 TB and Intake mani, but I don't see that mani bolting up just like that without some mods to it. My many has alot more shit than just 3 holes... that tranny swap is not till next summer anyways but we'll get there.
After that tranny swap the car is going to go thru some nice mods exhaust set up, either a Turbo or Surpercharger dunno yet... Turbo is hella cheaper. Interior, and finnally wheels.
Old 04-10-2006, 11:43 AM   #20
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
Turbo isn't necessarily a lot cheaper man, I heard about a good priced VF engineering supercharger.
Old 04-10-2006, 01:11 PM   #21
Rob
Rate My Car: 94 / 337
Schrick cams are tuned S50 cams, which work with the m50, m52, s50, and s52. So, the S50 WILL work in an M52, or even an S52. Now, the M52 and S52 cams will NOT work in an M50 or S50, because they have a counter balance on them which prevents them from going in.
As for your intake manifold setup, you need to reuse the M52 throttle body, because of OBDII and the different setup provided with it. The TB should bolt up exactly like before. The only reason of going with an M50/OBDI manifold is if you did an OBDI conversion, which isn't recommended unless you drop an engine into an early OBDI car, or for racing purposes.
Old 04-10-2006, 01:14 PM   #22
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
Originally Posted by Rob
Schrick cams are tuned S50 cams, which work with the m50, m52, s50, and s52. So, the S50 WILL work in an M52, or even an S52. Now, the M52 and S52 cams will NOT work in an M50 or S50, because they have counter balance on them which prevents them from going in.
Isn't that what we were saying when you said they won't work?
Old 04-10-2006, 01:18 PM   #23
Rob
Well, I was always told to stick with S52 to M52 and S50 to M50 cams. I will probably always stick to it, but if the S50 cams work for you, then more power to you.
Old 04-10-2006, 07:04 PM   #24
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
Ummm, I was going to say...something about checking the radiator....buuuuuuut you are already getting a new one. So that obviously isn't the problem.
I've seen it on an e36 M3, just makin' sure.
Sounds like TONS of fun. Don't hurt yourself.
Old 04-11-2006, 07:50 PM   #25
///Menace328i
I'm having fun doing it... taking my time...
Old 04-13-2006, 07:54 AM   #26
EuroStyle
Your Ride: 92 325i
If you are going to do this, I would suggest an Eurosport kit, or at least partial kit...http://www.eurosporthighperformance.com/cam_kits.html
Talk to these guys and see what they say
-Matt
cams rawhawk E36 2 10-10-2008 12:21 PM
Update on cams, advice on ECU PLS Rooz E36 71 09-05-2005 08:16 PM
Looking for digi cam beem United Off Topic  **FOR MEMBERS ONLY** 9 07-26-2005 02:47 AM
Cam Software komodo E36 4 06-16-2005 11:22 PM
Vanos komodo E36 16 05-31-2005 08:32 PM
