Old 03-26-2006, 09:12 AM   #1
Kiterunner
E36 Overheating.
Hi All,
Been busy with work and hence not quite active. Further, have managed to drop my lady and change to 18 inchers. I shall post the pics in a day or two.
But first, my lady nearly touched the red zone in the temp guage. Any inputs for me to check...? Cheers..
Old 03-26-2006, 10:11 AM   #2
Rate My Car: 134 / 340
Start with belt tension, (slipping fan belt turns waterpump slower) if that's ok consider changing waterpump, thermostat & doing a coolant flush also check for water in the oil - could be head gasket (right Rooz?)
Old 03-26-2006, 10:21 AM   #3
TJsBimm
Rate My Car: 225 / 340
Your Ride: 97 328i
clutch fan might not be kickin in. check for play
Old 03-26-2006, 10:38 AM   #4
Rate My Car: 184 / 340
you didnt do ANYTHING at all? was it real cold that the coolant may have frozen? and does it still overheat? can you give more details?
Old 03-26-2006, 04:43 PM   #5
B_w.
Rate My Car: 60 / 340
Your Ride: turbo e36
check the fan clutch and t stat. the fan might not be turning on.
Old 03-27-2006, 08:59 AM   #6
Kiterunner
Thanks all for your inputs. Had to take afternoon off.
This is what happend....
1. Water Pump broke down (Original Stock since 1997)
2. Thermostat Housing Cracked (Stock)
So had to get all these, New Water Pump, Thermostat housing, Housing Gasket and New Coolants....all from the local Bimmer Dealer.
Funny thing is ...all of em cost less than the OEM parts..he he he..
Thanks all....me lady is back in the mid zone...
Old 03-27-2006, 09:01 AM   #7
Kiterunner
All the belts are fine. No water inernally too. Did all the checks u'all advised.....thanks!!
Old 03-27-2006, 09:04 AM   #8
Kiterunner
Oh yes...a new fan as well...as one of the fins had vanished...JFYI, all the items cost me....BND 323.00 thats is an equivalent of USD 190.00. Remember all of the parts were from Local BMW dealer....
Old 03-27-2006, 09:05 AM   #9
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Rate My Car: 313 / 340
I think i have to change my water pump in the future.I think it's common E36 have faulty water pump.
Where did u chage it?QAF?
What's the milage on your car??
.BMW 328
Old 03-27-2006, 09:05 AM   #10
Kiterunner
BND stand for Brunei National Dollar
Old 03-27-2006, 09:05 AM   #11
Kiterunner
Got it changed at Modern Motors..Batu Bersurat.
Old 03-27-2006, 09:08 AM   #12
Kiterunner
mileage is apprx 119K
Old 03-27-2006, 09:09 AM   #13
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
i think i know where. I know it's near the Mall and Tungku link.
It is near shop where it burned down before??The place where Tamu Trader office used to be...
.BMW 328
Old 03-27-2006, 09:19 AM   #14
Kiterunner
Its just behind the block that got burnt down. Extreme corner...tel: 2450462. Talk to Shirley or AH Keong...
Old 03-27-2006, 09:25 AM   #15
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Sometimes bringing it to specialist can be scary. They can trick you by taking out the good ones and replace it with the bad ones. You go back there to fix the problem and they just replace back your original parts.
I was recommend at the Chua Automobilesby the Amedeo Mechanics( Gadong near /above Just toys) but they are bit pricey...
.BMW 328
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 33 08-11-2012 01:00 PM
DIY (please sticky):Blown Rear Shock Mounts!? E36 Tower Complete Replacment! delmarco BMW OEM Parts Department DIY's & FAQ's 9 08-27-2005 02:16 PM
A question about pre 1997 and post 1997 E36 seats! delmarco E36 4 08-20-2005 04:39 PM
E36 Floorboard Lights Installed! Took All Day/Awesome pictures! delmarco E36 13 08-19-2005 07:31 PM
This is the E36 I am looking to buy... mpowerd E36 36 07-15-2005 03:07 PM
