Old 03-27-2006, 12:31 PM   #16
Rob
Rate My Car: 94 / 337
Originally Posted by Kiterunner
Oh yes...a new fan as well...as one of the fins had vanished.
It sounds like you either need a fan delete kit or to check your engine mounts. A weak engine mount could result in a tilt while breaking and could put the fan in contact with your radiator, hence the missing blade. The fans in the e36 tend to gernade off as well, either because of the engine mounts, the fan going wack, or your water pump going bye-bye. That is why I deleted mine, never had overheating problems since. I believe understeer has a nice kit on their site that will get you where you need to be if you want to go that route.
Old 03-27-2006, 03:52 PM   #17
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
Yes, but does Understeer ship to Brunei? lol
Old 03-28-2006, 12:28 PM   #18
Rob
Why not? Their e-shop uses Paypal which calculates the shipping based on location. I don't see an issue with it at all, unless there are some crazy customs or something.
Old 03-29-2006, 12:50 AM   #19
Kiterunner
Thanks Rob....will do all the relevant checks this weekend..
Old 03-29-2006, 01:12 AM   #20
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Rate My Car: 313 / 337
Pay pal does not work in Brunei...
.BMW 328
Old 03-30-2006, 09:43 AM   #21
zeit00
zeit00's Avatar
Rate My Car: 38 / 337
I did not see thermostat on that list. If the car overheats it usualy kills the t-stat.. Try changing that.
Old 04-01-2006, 11:54 PM   #22
Kiterunner
zeit00..the thermostat is fine, changed the thermostat housing only.
Old 01-15-2010, 11:59 AM   #23
dougiesnowdon
Title: Read Only Club
Your Ride: 1997
E36 Heating problems
Hi..
I need some help.
I have a E36 323i Coupe (m52) and it keeps on overheating.. Ive replaced thermostat, thermostat housing and radiator.. At first when I replaced these parts, both hoses on the radiator were both getting hot but no heat was coming through into the car. I then replaced the heater valve and now the bottom hose on the radiator is cold and top is hot. I am now going to change the water pump.
Is there anything else it could be to save my pride and joy.
thanks
Old 02-07-2010, 07:08 PM   #24
karime302
Your Ride: E30 M3
thanks for this nice info
DIY (please sticky):Blown Rear Shock Mounts!? E36 Tower Complete Replacment! delmarco BMW OEM Parts Department DIY's & FAQ's 9 08-27-2005 02:16 PM
A question about pre 1997 and post 1997 E36 seats! delmarco E36 4 08-20-2005 04:39 PM
E36 Floorboard Lights Installed! Took All Day/Awesome pictures! delmarco E36 13 08-19-2005 07:31 PM
This is the E36 I am looking to buy... mpowerd E36 36 07-15-2005 03:07 PM
