Old 03-23-2006, 01:41 PM   #1
armybimmer05
armybimmer05's Avatar
Your Ride: 1992 BMW 318i
idle problem at startup
when I turn on my car and let it run for a while, it idles up to like 1.5 rpms (without pressing the gas) then it goes down to almost trying to cut off. After a while it goes back to normal but I could still notice the engine noise going up and down a bit when I stop the car. Anyone knows what could it be??
Old 03-23-2006, 01:55 PM   #2
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
My guess is your ICV (Idle Control Valve) is getting dirty.
It's a very simple process to clean it yourself if you'd like:
http://www.unitedbimmer.com/kb-e36-icvcleaning.php
Or if not, a mechanic will charge maybe $20-25 to do it for you.
Good luck with it though, and let us know how it goes.
Oh, and welcome to UB!
Old 03-23-2006, 01:57 PM   #3
Rate My Car: 137 / 337
Sounds like a vacuum leak. Check for cracked vac lines, loose or disconnected vac. hoses. A cracked bellows (large hose from air filter housing to MAF) will cause that also. At least start with the simple stuff.
Note: when was the last known fuel filter change? (Lots of condensation in gas when there's a good temperature change)
Old 03-23-2006, 02:00 PM   #4
komodo
komodo's Avatar
Your Ride: 1995 M3
Actually c1apton might be on to something. I didn't think of it at first, but when I had a vaccuum leak in my intake manifold a while back, it reacted exactly like you described...
Old 03-23-2006, 02:19 PM   #5
armybimmer05
I bought the car about 4 months ago and I haven't done a fuel filter change. This been happening for like 2 weeks now and it was worst when it was colder, the last few days wasn't too cold and it wasn't idling as bad as when it was below freezing.
I will check my vac lines and change my fuel filter...thanks guys for the help...
nice m3 komodo
Old 03-23-2006, 02:47 PM   #6
Avlany
Avlany's Avatar
Your Ride: 1995 Jet Black 325i
I dont think Fuel Filter does have anything to do with your problem. ICV or vacuum leak are the most possible explanations.
Dont piss me off. I am running out of places to hide the bodies
Old 03-23-2006, 05:21 PM   #7
///MDreain
Your Ride: 97 328i
Ahh my car is having the same problem, thanks for the tips guys.
*Image hosting service banned this link*
Montreal 328i
Old 03-23-2006, 05:35 PM   #8
komodo
komodo's Avatar
Your Ride: 1995 M3
Old 03-24-2006, 08:01 AM   #9
jms
jms's Avatar
Title: ______
Rate My Car: 102 / 337
Your Ride: 99 328I Convertible
I know this sounds crazy but also check your gas cap, mine was not closed all the way and I had a similar experience, except mine would actually stall, but it only takes a second to make sure it is closed all the way.
Old 03-25-2006, 12:57 PM   #10
armybimmer05
I clean my ICV today and it was dirty. Now is running a lot better. The only thing is that when i stop, i could hear the engine noise change a bit, not a bad as before but still does it. I will check the O2 sensor tomorrow.
Thanks guy for the help.
Old 03-25-2006, 03:17 PM   #11
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
that DIY is good. Ima try and clean my M42's.
UB FTW
Old 03-26-2006, 02:16 AM   #12
komodo
komodo's Avatar
Your Ride: 1995 M3
UB FTW
Old 03-26-2006, 09:42 PM   #13
defkon99
defkon99's Avatar
Rate My Car: 50 / 337
Your Ride: 1993 E36
same problem here wtf is it the weather?!!!!
Rough Idle + CEL Rooz E36 5 03-22-2006 09:30 PM
problem with cams e30boarder E21, E30 3 09-06-2005 09:44 PM
Traffic/Speeding Problem! komodo Comedy Collection
1 06-13-2005 09:24 PM
