Old 02-28-2006, 03:58 PM   #1
cabrit
cabrit's Avatar
water pump
when is it a good time to change a water pump what signs should i look for i am hearing a whistling type noise at low acceleration it whistles and i high no noise. somebody told me it might be the water pump which could also could be assiciated with my vanos rattling louder than usual
Old 02-28-2006, 04:07 PM   #2
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
I have an E30, things might be a little different. Although i think the pump is the same for the E36. Either way when mine started to go out i heard the bearing inside of the pump. It started to sounds..well like a bearing was going out. It got worse, and one day just went out.
Old 02-28-2006, 04:10 PM   #3
Rate My Car: 106 / 337
A whistling noise is usually something to do with vacuum hoses, YMMV.
If you bought the car used, or don't know when the water pump was replaced (if ever), then change it right away, assuming you're talking about an E36. You'll usually get no indication at all that it's about to go, but when it happens, 10 to 1 you're gonna be screwed. The newer compsite impeller pumps should last about 60k. Most of the metal ones do too, but some have issues with the bearings wearing out.
Water in tail lights? witeshark BMW OEM Parts Department DIY's & FAQ's 6 10-11-2011 07:09 AM
Fuel pump zeaq328i E36 12 04-28-2007 12:08 AM
need air pump to pass emissions? Spieluhr E36 2 09-06-2005 06:10 PM
Cheapest water pump price? Dudesky E36 7 08-02-2005 12:46 PM
