Old 02-20-2006, 05:32 PM   #31
///M Power
Rate My Car: 25 / 337
Your Ride: 95 m3 turbo
I could prolly find a great reputable shop through a supra buddy of mine who could do the install for $300 or so.
Old 02-20-2006, 05:42 PM   #32
jms
jms's Avatar
Title: ______
Rate My Car: 102 / 337
Your Ride: 99 328I Convertible
Originally Posted by ///M Power
$450 include the clutch?
why yes it did.
Old 02-20-2006, 05:46 PM   #33
jms
jms's Avatar
Title: ______
All told for $890 I had the clutch replaced, both belts replaced, brake switch replaced (the convertible is a little more expensive) and the radiator replaced. And a little bit of underbody stuff fixed. That includes all parts and labor. Unfortunately the guy I used is in eastern PA. by allentown/bethlehem. And unless you are there you have to shop around for a mechanic.
Old 02-20-2006, 06:08 PM   #34
Tochenzo
Tochenzo's Avatar
wow that's an amazing deal, ur lucky to have a reliable cheap mechanic like that
1998 Hellrot 328i
Old 02-20-2006, 11:19 PM   #35
TJsBimm
Rate My Car: 222 / 337
Your Ride: 97 328i
If the clutch is slipping usually 3rd and 4th full throttle after clutch has been released will tell you. That's when mine started slippin, those are your stompin gears and it sucks when she decides to give you higher revs than speed.
Old 02-21-2006, 01:21 PM   #36
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
People on bimmerforums say they can replace the clutch on their m3 in about 30-45 mins, is that anywhere near possible?
Old 02-21-2006, 01:39 PM   #37
Rate My Car: 137 / 337
Yea it's possible. Folks who do it alot can "bang" them out quick. Also with the right tools -(clutch alignment tool, hoist, air tools etc..) It's too bad you weren't closer to Minn. - I'll be home for a week next week and have a 3 stall shop, hoists, tools - going to do engine swap on "bird" and M5 front springs/struts on the E34.
Old 02-21-2006, 01:44 PM   #38
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
Awesome. DIY on springs?
Old 02-21-2006, 01:51 PM   #39
Thanks Harry, my guys are here reading over my shoulder (I'm arranging all their air fare home currently) and now they want to make a full blown video production of spring DIY. Sure we'll do it WTF.
Lets see:
2 M5 springs - $223.00
2 Bilstein Sport shocks - $220.00
Beer for audio & video crew - $600.00
Getting this done correctly - PRICELESS
Old 02-21-2006, 01:54 PM   #40
Tochenzo
Tochenzo's Avatar
i did those tests, here are results
after i shift from 3rd to 4th and i go full throttle, my revs go higher than my speed
when i start my car in 5th, it dies right away
when i shift from 2nd to 5th at 20 mph, my rpm's just drop a lot
so...i guess this means its slipping...but not too much?
1998 Hellrot 328i
Old 02-21-2006, 02:07 PM   #41
jms
jms's Avatar
Title: ______
yes that's exactly what mine was doing. You will want to get it changed soon or you risk damage to the flywheel.
Old 02-21-2006, 02:29 PM   #42
Storamin
Storamin's Avatar
Title: Road Kill
Well, the first test you did right. That tells you the clutch is slipping.
The second test is to try and start it in 3rd, not 5th.
The third test is to shift from 2nd to 5th at 20mph and give it full throttle. You should experience something similiar to 3rd to 4th and go full throttle.
Spongy? clutch pedal Dudesky E36 3 11-28-2005 05:37 PM
Clutch Issue? dinan540 E12, E28, E34, E39, E60 19 10-24-2005 12:05 PM
Clutch Install pics! 56k...nah devinwwu E12, E28, E34, E39, E60 4 08-04-2005 04:34 PM
Just ordered a LW Flywheel and Stage 3 clutch devinwwu E12, E28, E34, E39, E60 5 08-02-2005 11:40 AM
FS: LTW Flywheel & Clutch Kit mpowerd Bmw Cars For Sale/Wanted 10 06-30-2005 07:55 AM
