Old 01-30-2006, 10:17 PM   #1
Kiterunner
Headlight Focal Point Adjustments
Hi, All.
Can anyone throw light on the actual procedure to adjust the low & high beams of the E36.? The standard distance between car and wall, the beam(s) location and of course with the hydraulic adjustment switch (if i got that right) too. Thks..
Old 01-31-2006, 11:22 AM   #2
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Rate My Car: 313 / 337
Is it too bright?
.BMW 328
Old 01-31-2006, 05:24 PM   #3
Kiterunner
Naah....changed back to stock with eyelids. The electrician is on leave..CNY. Thought we all get to know the focal points of the beams and their factory settings....no one seems to know..(YET)...
Old 01-31-2006, 10:23 PM   #4
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
I haven't done it with my stock headlights even though I changed my bulbs. Have you tried just shining your lights at a garage door, or wall and try to adjust them that way?
Old 02-01-2006, 01:17 AM   #5
Kiterunner
Yes, did that. At the moment, they seem fine. But I am sure there is a focal distance for the beams. Shall try and get some info from the BMW dealership guys and do up a schematic diagram for all...
Old 02-01-2006, 01:18 AM   #6
Kiterunner
Funny thing is....at what distance do you park the car from the wall / garage door...????
Old 02-01-2006, 04:35 AM   #7
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
My garage has no wall
.BMW 328
Old 02-01-2006, 05:18 AM   #8
Rate My Car: 106 / 337
Ahhh, the lost forgotten art of aiming headlights Most people don't bother because many state inspection centers no longer check this. This procedure applies to any car, and not specific to an E36.
If you wanna be really anal about it, check your tire pressures, have 3/4 tank full of gas, and add the driver's weight to the driver's seat. A flat level surface with a perpendicular wall is of course required. Pull as close to the wall as possible, and mark or tape a horizontal line across the hotspots of your low beams. Then mark the vertical lines. Your marks should then look like this:
Alternatively and more accurately, you can measure the distance from the center of the low beam bulbs to the ground, and transfer that measurement to the wall, and mark your verticals dead ahead of the bulbs. But it's not necessary unless your lights are really whacked and you're lighting up rooftops as you drive by
Back up to 25ft from the wall and adjust the low beams so that the hotspots are 2" down and 2" to the right of the wall marks. Just for reference, the high beams should be about the same height, but centered 3" in from either vertical mark. But this doesn't apply to your E36, since the adjustment is at the housing, not on the individual lights.
Now for the reality check: the hotspots obviously get bigger as you back away, so how the hell do you measure 2 or 3 inches?! Just move the lights a smidge in the said direction
Old 02-01-2006, 06:53 PM   #9
Kiterunner
Thanks, a lot. Will set em this weekend...
