Old 01-29-2006, 10:09 PM   #1
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
My trunk flooded
I took my car for a wash today. And apperantly the seal just below the window on which the trunk lid sits on is loose. So when i opened up my trunk to grab some stuff out of it everything was soaked. Like everything exept a hat i had in a box was completely soaked. The carpet even had some foam from the car wash on it.
Now i took it out and set it to dry. But should i have dried it with like a blow dryer or something? or is it gonna be fine if i just let it air dry?
Old 01-29-2006, 10:59 PM   #2
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
Ah, that sucks.
I bet you didn't think shampooing the carpet of your trunk was part of the package when you bought it.
Old 01-29-2006, 10:59 PM   #3
Rate My Car: 84 / 337
I would think leaving it open to air out would work well enough
Old 01-29-2006, 11:22 PM   #4
Rate My Car: 183 / 337
yea dont close it, b/c then it will be damp and annoying, just leave it open for a few days
Old 01-29-2006, 11:56 PM   #5
BMWLotAttendant
Title: I Drive EVERYTHING
Your Ride: 1997 Camry CE
Get a wet vac and get all the water out, and then let it air dry....
Or stick a fan in there.
Old 01-30-2006, 05:20 AM   #6
Rate My Car: 106 / 337
^^^Yes, vacuum up as much moisture as you can and let it air dry the rest of the way. If you leave it soaked, residue from underneath the carpet may surface, leaving a wet spot. Or better yet, you may as well clean the whole thing with carpet cleaner.
Old 01-30-2006, 06:18 AM   #7
Rate My Car: 137 / 337
Like all the guys previously said get all the "removables" out and dry -shop vac, air dry whatever. Get ALL the moisture out of trunk especially behind wheel wells (those lower wells) Don't let moisteure sit there and don't forget spare tire well. Even spread "oil dry" around and vac that out to prevent rust from taking hold and mold forming.
Old 01-30-2006, 09:45 AM   #8
tomctx
I would especially check around the battery well.
my car flooded Hoppy E12, E28, E34, E39, E60 17 10-16-2005 08:53 PM
Undercoating trunk Rooz E36 22 09-12-2005 09:18 AM
So, How Screwed Am I? What I found in my trunk! (pictures) delmarco E36 23 08-26-2005 05:40 AM
Trunk Will not Open, any ideas nick_318is E21, E30 6 08-14-2005 01:21 PM
Trunk impaired e36 precisiongrafx Bimmer Showroom 22 06-29-2005 06:25 PM
