Old 01-18-2006, 06:57 PM   #1
catalyst
Rate My Car: 197 / 337
Your Ride: 1994 325is
car=down
My clutch just took a dump on me..
brakes work, so i doubt its leaking fluid, most likely a dead slave as it was working perfectly fine previously.
discuss..
Old 01-18-2006, 07:36 PM   #2
Rate My Car: 183 / 337
dead slave.. is it just not disengaging? it might be your pressure plate, happened to me
Old 01-18-2006, 07:36 PM   #3
let me add though, i think we all hope its NOT the pressure plate
Old 01-18-2006, 08:32 PM   #4
Rate My Car: 106 / 337
Originally Posted by catalyst
discuss..
No discuss. Fix. Get underneath that badboy and wrench it into submission.
Old 01-18-2006, 08:48 PM   #5
RealBmw 02
Title: GRIP > DRIFT
Rate My Car: 78 / 337
Could be a bad master or slave cylinder. Mine went bad a few years ago and I just replaced both to be safe. However, when mine went bad it was not a sudden issue. I first noticed it when I would be at stop lights for over a min. The car would start to creep forward if I did not have the brakes on, and if I did the car would stall. Did you ever notice this happening to your car. It seems unlikely that the master or slave cylinder would fail all at once.
1970 BMW 2002
Driven by skill, not money
Old 01-18-2006, 10:02 PM   #6
catalyst
yes lets hope..
let me just say, not having a garage sucks.. like hardcore.. this is gunna be a PITA in this weather..
it was sudden.. no problems before, but i ussually always drop to neutral at stops so, idk, its possible.
Old 01-18-2006, 10:05 PM   #7
RealBmw 02
Title: GRIP > DRIFT
Question: If you are in neutral with the car running and you pump the clutch a number of times, are you able to even get the car into gear at all?
1970 BMW 2002
Old 01-19-2006, 03:45 PM   #8
catalyst
no i tried that, it refuses to go into gear..
sounding more and more like its not the slave..
Old 01-22-2006, 08:30 PM   #9
catalyst
Well, i am 90% sure that there something up with the pressure plate or something along those lines so..
Im going with an m3 flywheel and sach's M3 clutch kit.. (clutch disc, pressure plate, to bearing)
expect pics and a write up now that i have a good camera.
