Old 01-05-2006, 05:43 AM   #1
Rate My Car: 106 / 337
Spark plugs
About to change out my spark plugs for the first time (Bosch OE dual electrode). And I got to thinking which train of thought is correct: Will the new ones tax my electrical system more because they're newer, or are the old ones taxing it more right now because they're old and inefficient? I'm expecting some sort of change since my car is up there in mileage.
Old 01-05-2006, 06:05 AM   #2
Rate My Car: 137 / 337
Your old plugs are taxing your ignition system because of resistance rises as they wear. After putting in new plugs although they won't be "taxing" your ignition, the addition might amplify any (if any) existing problems. I think you'll notice faster starts, quicker response and better mileage
Old 01-05-2006, 08:01 AM   #3
Makes sense. Yea, I'm expecting the dreaded 'problem amplification', or the old 'fixing one thing breaks another thing' syndrome
Old 01-05-2006, 08:08 AM   #4
Make sure you do the plug change when engine is cold and the plugs have a dab of anti seize compound on the threads.
Old 01-05-2006, 10:51 AM   #5
Yea, when cold, I knew that part. But the anti-seize thing . . Some say don't use it as it interferes with the ignition current flow. Thoughts anyone?
Old 01-05-2006, 12:34 PM   #6
That's why I mentioned a "dab". Alot of plugs these days come pre coated but just a small dab just to keep threads from seizing.
Old 01-05-2006, 02:53 PM   #7
kestrel325is
kestrel325is's Avatar
Your Ride: 1995 325is 5-speed
I've always put a small amount of motor oil on the threads before inserting the plug. Holdover from what my Dad taught me when I was younger.
Old 01-05-2006, 03:37 PM   #8
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
what does changing them when they are hot do?
I am worth $2,022,318 on HumanForSale.com
Old 01-05-2006, 03:59 PM   #9
The plugs are prone to gumming up when hot. More importantly, you'll have a harder time getting them off when the engine is warmer, risking cracking or cross threading.
Old 01-05-2006, 04:42 PM   #10
also when engine is hot & you pull plugs the actual plug holes can distort.
Old 01-06-2006, 07:51 AM   #11
billycuth
billycuth's Avatar
thanks guys. good info. never heard that.
Old 01-06-2006, 08:37 AM   #12
jms
jms's Avatar
Title: ______
Rate My Car: 102 / 337
Your Ride: 99 328I Convertible
I've heard not to use platinium, only use copper but I've also heard plats are fine. Anyone have any idea who's right?
dudesky which are you putting in, and more importantly what did you take out?
Old 01-06-2006, 08:42 AM   #13
I use the platinum 4s (they came with car from factory) From what I've heard coppers work fine, just don't last as long. That's the only negs I've ever heard that were credible.
Old 01-06-2006, 09:20 AM   #14
billycuth
billycuth's Avatar
I did platinum +4s a little while back... caused misfire problems and I immediately cracked a couple of them within a week. BMW shop told me not to use platinums as the 328i (e36) doesnt create enough spark to warrant their use. OEM copper is the way to go, I am told.
Old 01-06-2006, 09:25 AM   #15
Yea again it's what the car is designed for. Mine came factory with the 4s and they work great. Friends who have tried to save a $ went with coppers only to have them last like 15k before noticing mileage drop and lags. But I've heard the similar to what you said, sometimes upgrading isn't feasible (mostly hype from plug mfgrs)
Spark plug replacement & compression test DIY Dudesky BMW OEM Parts Department DIY's & FAQ's 21 10-18-2010 10:22 PM
Spark Plugs Upgrade soon... ///Menace328i E36 12 09-07-2006 10:47 PM
DO NOT go with Bosch Platinum +4 spark plugs billycuth E36 20 08-05-2005 12:17 PM
