Going by the fact that I probably have a bad piston, and that I might have to replace it, was wondering if I could just upgrade all of them at once to some more performance driven pistons. Anyone know of any?
if you buy all 6 pistons, it will cost you, now, if your giong to turbo your car, you might as well do all the internals now and worry about the turbo later, but if your just driving your car normally, i dont see the reason why you should upgrade
How the heck can you get a price for pistons on that site?
pistons, rings, roads, and you may even bore them out, but then again now that i think of it, you might as well replace ALL your rings b/c you dont want to be opening your engine up again
Your Ride: 92 325i
Originally Posted by Rooz
Yeah, I mean, I really don't mind replacing all my rings and pistons now, just a question of finding some nice performance ones...
For the money just swap your m52 w/ an s52 (that has a manual transmission attached to it).
But seriously, if you are looking for piston upgrades, pull the engine, strip the block have it bored to 86.4mm and replace your m52 crank, rods, pistons, and rings w/ s52 parts. Swap in your m3 cams, Contact AA Tuning about the 800.00 custom software, and for God's sake fit a manual tranny to the motor before you reinstall it.
I think before you consider pistons you should consider adding another pedal.
Let me know if you need more info on the m52/s52 parts swap.
-Matt
