Old 12-21-2005, 11:05 AM   #1
dennis1128
325I Died
My 1994 325I quit while driving through an intersection a couple of days ago. After it sat for 3 or 4 hours it started and ran for 30 seconds or so then died and wouldn't start back. Towed home. Still hasn't started after a couple of days. Haven't had time to actually check it out other than the codes. Got the 1444. No help there. Realize it could be multiple things, but I would greatly appreciate any input of possible causes. Turns over fine, has new battery. Was in low 30's when this happened. Was going to start with plugs then move to fuel. Thanks for any input.
Old 12-21-2005, 12:04 PM   #2
jms
jms's Avatar
Title: ______
Rate My Car: 102 / 337
Your Ride: 99 328I Convertible
wow, that sucks. I would start with fuel. Check your gas cap. I had mine stalling and running like crap and my gas cap was improperly seated. That fixed everything. beyond that I would change my fuel filter. Both are easy and relatively cheap. Plugs are possible but not likely if it runs for 30 seconds or so.
Old 12-21-2005, 01:56 PM   #3
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
Was there a letter before the 1444 code? i.e P,F,B,C If there was i can find out what the code means for ya
Old 12-21-2005, 02:02 PM   #4
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
only input I can give you is right now, I most definetly feel your pain too
http://www.unitedbimmer.com/forums/thread5596.html
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 12-21-2005, 02:03 PM   #5
german speed demon
Name: german speed demon
Your Ride: 88 325is
Check the fuel pump relay. My old e30 323 sat for 6 months before i bough it b/c it woulndt run. fifty bucks later, i'm driving an awesome car. Worth a shot anyway.
Dave
booyah.
Old 12-21-2005, 07:06 PM   #6
Rate My Car: 106 / 337
He means to say that there were no codes thrown. 1444 means there are no faults stored
I'm betting on the fuel filter or the fuel pump, although that should have thrown a code.
Old 12-21-2005, 08:00 PM   #7
TJsBimm
Rate My Car: 222 / 337
Your Ride: 97 328i
I'd say fuel pump had a car once that acted like that....good luck
Old 12-22-2005, 02:49 AM   #8
Spieluhr
Title: ///M Driven
on the contrary it depends on if you have OBD I or OBD II. If you have OBD II and it is P1444 it means "EGR Valve Position Sensor range/performance" but since he has a 1994 he has OBD I which as you said means there are no faults. not trying to be anal, just in case someone with OBD II gets that code and thinks they dont have any faults.
I agree with what most have said here. Work with ignition and fuel first.
Lookinf for E30 325i / 325ix touring Barosz E21, E30 11 08-12-2011 01:29 PM
Mr. Miyagi Died komodo United Off Topic  **FOR MEMBERS ONLY** 1 11-28-2005 05:17 PM
94 325i Spring Coil issue mammajamma E36 8 11-16-2005 02:25 AM
Green Giant Died komodo United Off Topic  **FOR MEMBERS ONLY** 7 10-28-2005 02:52 PM
My Car Just Died. komodo E36 132 10-24-2005 05:14 PM
