Old 12-17-2005, 07:36 AM   #1
singring
Do I Need to Replace DME Chip ??
My defective ignition coil-pack cooked an ignition transistor in the DME of my 1995 318i Automatic. I have replaced the ignition coil-pack, and I have a used DME ordered, which should arrive in a few days. The used DME came out of a 1995 318i Automatic, and the Bosch part numbers all match perfectly. Before the DME module arrives, I am going to change the system relay, as well, just to be on the safe side.
My question: should I replace the DME chip in the used DME module, that's on it's way, with my original DME chip from the stock DME module from my car?
Or, should I just try the used DME module, as is?
I've boned up on changing the chip, from PelicanParts site, and it seems like an easy process.
Any other words of advice before I turn the ignition key?
thanks
Old 12-17-2005, 08:54 AM   #2
Rate My Car: 137 / 337
Try the "replacement" unit as is - make sure it works first. If you feel adventurous then try the swap, but you're risking the same results as first problem.
installing a perfomance chip cabrit E36 50 07-06-2006 02:11 AM
Need DME Ignition Transistor singring E36 1 12-15-2005 10:28 AM
How to replace a radiator in a 540i Cambridge E12, E28, E34, E39, E60 1 12-02-2005 05:58 PM
Racing Chip mammajamma E36 5 11-24-2005 12:25 AM
Conforti Chip mrkbik E36 9 06-23-2005 07:39 AM
