Old 12-15-2005, 09:36 AM   #1
singring
Need DME Ignition Transistor
Hi,
My 1995 318i DME ignition transistor cooked my #2 ignition coil. I removed the DME, and I can make the repair, if I can find a replacement
transistor. So far, I've had no luck locally.
My DME part number is 0 261 203 282.
The transistor has the following numbers, arranged as printed on the transistor body itself:
16401 4994
C 30051
The transistor manufacturer's logo looks like a modified "circle-H".
Can't find anything on that logo on the internet, and the electronic supply shops here have never seen it before either.
Are these transistors available anywhere?
Old 12-15-2005, 10:28 AM   #2
Rate My Car: 137 / 337
Try contacting Vertex Auto.com or Mouser.com - these guys might be able to help you. (vertex rebuilds DMEs) Good luck
Plasma Ignition System Rooz E36 25 03-15-2006 10:58 PM
High performance Ignition coils Rooz E36 33 03-06-2006 03:48 PM
No Battery Voltage to Starter singring E36 2 01-09-2006 09:20 PM
Do I Need to Replace DME Chip ?? singring E36 1 12-17-2005 08:54 AM
