Old 12-15-2005, 08:02 AM   #1
jms
jms's Avatar
Title: ______
Rate My Car: 102 / 337
Your Ride: 99 328I Convertible
Help - I got a wierd problem
here's what is going on.
I shift and drive and everything is normal until I get on the highway. in 3rd 4th and 5th gear everything is fine until I get above 3500 rpm after that I lose power but the engine continues to rev. It feels kinda like the clutch is partially dis-engaged but I'm not riding the clutch. I don't know what to make of it.
Has anyone experienced anything like it?
Old 12-15-2005, 08:09 AM   #2
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
I havent, and unfortunately mine is auto, but it could be that the clutch needs adjusting?
I am worth $2,022,318 on HumanForSale.com
Old 12-15-2005, 08:18 AM   #3
Rate My Car: 137 / 337
How many miles on car? If it's high mileage it might be time for a clutch.
Old 12-15-2005, 08:34 AM   #4
jms
jms's Avatar
Title: ______
83k, it very well may be but shouldn't first and second be affected?
Old 12-15-2005, 08:39 AM   #5
Doesn't sound like mileage is too high. re: 1st & 2nd gears, slipping in higher gears is early warning that clutch is bad or out of adjustment because in higher gears there is more "load" on overall drivetrain. I'll bet is adjustment, if I remember right that's a fluid clutch.. check the brake fluid level. How's the pedal pressure?
Old 12-15-2005, 09:02 AM   #6
jms
jms's Avatar
Title: ______
pedal pressure seems fine, I'll check the brake fluid the next time I'm outside. I'm not afraid of having the clutch replaced. I just want to be certain that it is going to solve the problem. I think you are right it is a fluid clutch. This just started happening since the weather got below freezing, is it possible that it may be fluid related?
Old 12-15-2005, 09:08 AM   #7
yea, you might have low fluid and or possible leak at fitting. Cold temps will cause that. You might to check record on last "brake flush". Brake fluid absorbs moisture and under pressure will compress. Keep me posted. I'll be on/off all day -{writing articles for audio magazines - fun?)
Old 12-15-2005, 10:46 AM   #8
Storamin
Storamin's Avatar
Title: Road Kill
sounds like you should replace the brake fluid.
Old 12-15-2005, 10:47 AM   #9
jms
jms's Avatar
Title: ______
the Brake fluid level is fine, I don't know when the last flush was. I only have about 2 years worth of records.
Old 12-15-2005, 10:52 AM   #10
I think I have it flushed. Before doing anything major.
Old 01-01-2006, 08:40 PM   #11
jms
jms's Avatar
Title: ______
Well here is the final word, it was the clutch. Unfortunately I got into an accident on the way to have it put in. But I figured I would wrap up the thread in case someone stumbles across it in the future.
Old 01-02-2006, 12:04 AM   #12
Rate My Car: 84 / 337
Thanks jms for the update
Old 01-02-2006, 12:32 AM   #13
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
Sorry to hear about the accident.
Old 01-14-2008, 09:48 AM   #14
iamcreepingdeath
iamcreepingdeath's Avatar
can an E36 clutch be adjusted? and if so how? My brother is having a similar problem. Did you just replace the clutch or did you adjust it?
Wierd vibration at high speeds projal147 E36 24 07-24-2010 02:43 PM
problem with cams e30boarder E21, E30 3 09-06-2005 09:44 PM
anyone think its wierd, airliner crashes Hoppy United Off Topic  **FOR MEMBERS ONLY** 15 08-24-2005 04:28 PM
Anybody can slove this problem? zeaq328i Geek Chat 14 05-08-2005 02:15 PM
