Old 12-03-2005, 02:11 PM   #1
DEATH2000
DEATH2000's Avatar
Rate My Car: 123 / 329
Right front tire issue
My car's been sitting in the garage for a while now, so today when i go out to get gas in it, the right front tire is really low on air. So im thinking shit, that aint good. I drive over to the ghas station and after about 10 agravating minutes the tire still doesnt have any air in it. It looked just as low as when i first saw it. It pissed me off that it wasnt inflating. Could it be the cold? Or will i probably need a new tire?
Old 12-03-2005, 02:21 PM   #2
Spieluhr
Title: ///M Driven
first off, gas station air pumps never hook up properly to the tire. You need to go to Les Schwabb, Discount Tire, or whatever professional tire place you have in the area. They will check the pressure for free most likely. It is either a slow leak, or you might have a nail or something in the tire, because you said it wasn't totally flat, in which case you can probably patch it.
Old 12-03-2005, 02:36 PM   #3
DEATH2000
DEATH2000's Avatar
^^ Thanks, im scared to drive it thouch cause its icy and theres lots of snow. I doubt its a nail cause the car hasnt moved in 30 days, and it was fine when i left it.
Old 12-03-2005, 02:54 PM   #4
Rate My Car: 173 / 329
1st of all, dont be afraid to drive it, unless its TOTALLY flat, b/c actually tires that arent fully inflated are better in the snow b/c there is more surface touching the ground
since its probably not a nail, it could be b/c when the tire was first put onto the RIM there is a black seal that goes around it, since its getting cold, it could have cracked and is letting some air in.. whens the last time you changed your tires?
Old 12-03-2005, 02:54 PM   #5
Spieluhr
Title: ///M Driven
then probably just a slow leak, nothing to worry about. but first off, you never want to let your car sit for 30 days. even if you just start it and let it run for a while, rev it a little. it will preserve it much more. Car's don't like to sit, it's hard on the engine, suspension, and tires.
Old 12-03-2005, 03:16 PM   #6
DEATH2000
DEATH2000's Avatar
Yea i know, but i had pretty much no choice. I wasnt allowed to drive it until today. And i did start it once in a while, just wasnt able to move it sadly.
The tires that are on there now are the tires that were on the car when i bought it in late april of this year.
I was gonna put on the spare, but the lug nuts are bieng a pain in the ass and wont come off. So ill just drive it to the nearest tire place see what they can do. Thanks for the help
Old 12-03-2005, 03:31 PM   #7
DEATH2000
DEATH2000's Avatar
Heres the tire as sits in my garage right now:
Old 12-03-2005, 03:35 PM   #8
catalyst
Rate My Car: 192 / 329
Your Ride: 1994 325is
Are you sure you were putting air into your tire?
That doesnt look completely flat, but if it wasnt holding air then its obviously leaking somewhere.
Old 12-03-2005, 03:43 PM   #9
DEATH2000
DEATH2000's Avatar
Thats the thing, im not 100% sure air was getting in.
Old 12-03-2005, 03:50 PM   #10
Rate My Car: 102 / 329
Get a spray bottle and spray the shit out of the wheel with water. then try and inflate it, see where the leak is comng from, if any. Then go from there. Depending on where the hole is, there are tire repair kits you can buy that don't require removing the wheel off the hub.
Old 12-03-2005, 04:06 PM   #11
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 329
You might have a slow leak, i would suggest you do what was said above
Old 12-03-2005, 04:43 PM   #12
Storamin
Storamin's Avatar
Title: Road Kill
take it off and take it to a tire place and have them check the pressure. use the spare. to break the lug nuts use your foot. that always works for me...
xsperf, the wider the tire the worse it will handle in the snow. the wider it is, the more it acts like a plow when turning in snow. this is why cars have typically narrower tires for winter, and wide tires for summer performance.
Old 12-03-2005, 05:46 PM   #13
DEATH2000
DEATH2000's Avatar
Well i appreciat all your help. I took it to Kal tire nearby, and yea it kinda does have a slow leak, so im just gonna keep an eye on it and if it gets bad again ill just throw on the spare.
And the air hose at kal tire inflated it in like 5 seconds, were as the gas station one did nothing. It was retarded.
Old 12-03-2005, 06:06 PM   #14
Rate My Car: 136 / 329
Depending on how long the car's been parked and temp differences, tire pressures can drop easily. A 5 degree temp change down can cause a 1-3 psi drop. That's why tire cos always preach check tire pressures monthly. When you start off cold in the morning and drive 5 miles tire pressures go up 2+psi - always check tire pressures cold.
Re: Gas station air pumps - they're pretty questionable and their "customer use" pressure guages. Alot of those outside air pumps get moisture in the brass coupler and freeze and don't always open when you attatch to your valve stem.
E36 M3 Front Bumper Rooz Bmw Cars For Sale/Wanted 10 11-21-2005 10:01 PM
MPerformance May Special on JT-Designs Front Strut Bar Jon@MPerformance Bmw Cars For Sale/Wanted 6 06-12-2005 05:36 PM
Kumho Drift Tire Torque United Off Topic  **FOR MEMBERS ONLY** 33 05-08-2005 07:23 PM
4/20 - blew a tire!!! ARGH (sorry no pics) woobiee BMW General Discussion 17 04-30-2005 01:44 PM
E46 Audio Information - This is a god-send. EcianIce Car Audio and Electronics 4 04-21-2005 03:22 PM
