Old 12-02-2005, 02:39 PM   #1
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
Weird issues....
CEL goes off, so I go to pull the codes off the diagnostic port, and I get nothing. No fault codes.
My warning computer tells me to check coolant level. So I check it this morning when the car is cool, and there is plenty of coolant. Weird.
Anyone ever have these types of issues?
I am worth $2,022,318 on HumanForSale.com
Old 12-02-2005, 02:50 PM   #2
Rate My Car: 136 / 329
Sometimes if the coolant level sensor sticks(after sitting overnight) it'll trigger CEL & OBC. If it starts happening on regular basis, you're probably looking at sensor replacement. They're notorious for sticking from scale buildup in cooling systems.
Old 12-02-2005, 04:14 PM   #3
Rate My Car: 102 / 329
Are you sure you're looking at the CEL? The "Check Coolant Level" OBC warning triggers the CHECK light on the instrument panel, not the CEL. They're 2 different things. And most of the time the electrical contacts on the sensor just need cleaning.
Old 12-03-2005, 06:54 PM   #4
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
Yeah mine went off yesterday and today in the OBC, ill check it tomorrow.
Old 12-03-2005, 09:48 PM   #5
BaLAnCe17
BaLAnCe17's Avatar
Your Ride: 1998 m3 coupe :-D
mine has done that once before. it went on and off for about a day. stayed off for about a week, then came back on. i eventually mixed coolant and water (the suggested mixture or whatever) and filled it up over the line. no problems since
Old 12-05-2005, 10:21 AM   #6
billycuth
billycuth's Avatar
yes, they are 2 things. which is why I am confused. The on board computer only says "check coolant level" after a significant driving period. It has been coming on intermittenly for a few weeks now (i live in PA, but the freezing thing doesn't make sense since it is after I drive it, not after it's cooled down).
The CEL below the odometer went off last week for no reason, and when I checked the codes, I got no feedback (no fault codes)... Now it seems to have gone off again. I wonder if my computer is going?
Old 12-05-2005, 10:22 AM   #7
billycuth
billycuth's Avatar
when the engine is cool, the coolant is slightly over the line. After driving it, I can't see the coolant level through my resovior (obviously, I can't open it while it is hot).
Old 12-05-2005, 10:30 AM   #8
Remove the cap when cold, start and let it warm up (w/cap off) It's sounds like you might have to "bleed" air out of the system.
Old 12-05-2005, 10:45 AM   #9
billycuth
billycuth's Avatar
that's it? just warm it up without the cap on to bleed it? sounds easy enough.
Old 12-05-2005, 10:54 AM   #10
Not exactly, there's a little black plastic screw next to filler (if I remember right) you just loosen that until coolant just starts to come out. then it's bled.
Old 12-05-2005, 11:31 AM   #11
What I mean is, aside from the computer in the center dash, there is a "CHECK" light by the odometer, and there is also a "CHECK ENGINE" light there as well. What you probably saw was the CHECK light, not the CEL, which is why you dn't have any codes showing.
Old 12-05-2005, 12:25 PM   #12
billycuth
billycuth's Avatar
thanks dudesky, but it was definitely the CEL. The check light has never come on for me.
Home Computer Issues dinan540 Geek Chat 20 02-01-2006 01:37 AM
Super weird question witeshark United Off Topic  **FOR MEMBERS ONLY** 11 12-12-2005 09:45 AM
This is weird mrkbik United Off Topic  **FOR MEMBERS ONLY** 11 12-12-2005 08:58 AM
Real quick, Weird people + Race bitcore Kill Stories 3 09-06-2005 06:43 AM
im having hardware issues... e30boarder Geek Chat 15 08-08-2005 04:09 PM
