Old 11-23-2005, 12:19 PM   #1
ivopivo
ivopivo's Avatar
Rate My Car: 142 / 329
Your Ride: 1993 BMW 325i and 2009 Yamaha R6s
yes or no....
to fan delte mod ? I've heard some bad stories of overheating and I've heard people that have no problems whatsoever once the do the fan delete. I just ordered a kit from understeer but am debating on selling it. I'm leaning towards installing it since I can always just change the t-stats and switches and put the fan back on, but then I think why even go through all the trouble. I just want to know what everyone thinks about this and please post only if you have done the fan delete mod or know the situation of someone who has done it. Is it like a proven thing that if you do everything right there should be no overheating at all ? I read somewhere that the car "only" overheats if it's idling for a long time. I don't want any overheating. post away...
-Ivan
LUSTR Auto Detail
"Always start with the least aggressive method!"
Old 11-23-2005, 12:44 PM   #2
Rate My Car: 102 / 329
Wow, this issue has been beaten to death with a stick Take it from all us guys who have done it- it works, and there is no overheating problems whatsoever unless you do it wrong. Flush & bleed the system properly, use the Water Wetter, and make sure the rest of your cooling system is up to snuff. Then you will be good to go
Old 11-23-2005, 12:48 PM   #3
Rooz
Rooz's Avatar
Rate My Car: 7 / 329
Your Ride: 2003 M5
yeah, just do a search and you should find several LOOOOONG threads on this....
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 11-23-2005, 12:58 PM   #4
DEATH2000
DEATH2000's Avatar
Rate My Car: 123 / 329
Do it, personaly i would do it. Since u already oredered it youd end up losing money by seliing it. After the fan delete i say get underdrive pullies
With the pullies, you notice a good difference in torque and power. Your accelration is faster and and u feel the power qucker than stock.
Old 11-23-2005, 01:12 PM   #5
///Menace328i
Your Ride: 1998 328i
I say do it... I will be doing it soon along with the scheduled tune up... while that is going on I will be doing some upgrades like FDM ofcourse... plugs... pads, rotors and lines...
Redefining Ballerism!
Old 11-24-2005, 01:48 AM   #6
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 72 / 329
Your Ride: 1995 M3
http://www.unitedbimmer.com/forums/thread2752.html
http://www.unitedbimmer.com/forums/thread3743.html
Read those two threads and you should be up to date on the general opinion of the fan delete.
Old 11-25-2005, 01:15 AM   #7
B_w.
Rate My Car: 65 / 329
Your Ride: turbo e36
go for it. i have never had problems since removing my fan. my bros 92 325is overheated the other day when he was charging the battery after he left his lights on
if you pay attention to the temp you will never get into trouble.
Old 11-25-2005, 11:05 AM   #8
///Menace328i
you how much power are you putting on the ground with that set-up you got there?
