Old 11-07-2005, 01:33 PM   #1
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 72 / 329
Your Ride: 1995 M3
Fluidyne Aluminum Radiator
I've heard a lot of people talking about how they wanted to upgrade to these, but what advantages do they offer? Can anyone shed some light on this for me?
Thanks.
Old 11-07-2005, 02:50 PM   #2
DEATH2000
DEATH2000's Avatar
Rate My Car: 123 / 329
Aluminum conducts heat alot better than normal metals such as steel. So used a a radiator it would help keep water temp kooler than a normal steel radiator
Old 11-07-2005, 03:02 PM   #3
bitcore
bitcore's Avatar
+ aluminum is considerably lighter than steel
If my fan blades keep poping into the radiator and cut a hole, then I'll have to look into getting a new one....
Old 11-07-2005, 03:07 PM   #4
komodo
komodo's Avatar
Your Ride: 1995 M3
So there's no real advantages unless you're having cooling problems?
Old 11-07-2005, 03:10 PM   #5
drz
Title: local dumbass
Rate My Car: 32 / 329
Your Ride: E36 2.8i
Running cooler is an advantage, plus there is the weight reduction, which many consider an advantage.
Old 11-07-2005, 05:06 PM   #6
Rate My Car: 136 / 329
PROS:Running an aluminum radiator disipates heat better - you can run a smaller radiator, smaller amount of coolant to get by for the cooling side of eng needs. Weight would greatly be decreased
CONS:Usually have to change thermostat and your heater efficency will suffer (like little or no heat) and they are very fragile (bugs, rocks, etc ) punture very easy.
Old 11-07-2005, 05:54 PM   #7
///M Power
Rate My Car: 23 / 329
Your Ride: 95 m3 turbo
The great aluminum radiators offered by Fluidyne, Zionsville, and AATunign are all great. Most of them are aluminum which saves wweight, and much more importantly, have larger capacities. AATunign is almost twice as expensive as Fluidyne or Zionsville. Go with fluidyne or Zionsville.
Old 03-10-2006, 11:50 PM   #8
gwumpkus
are fluidyne radiators a direct fit pls? i dun see one for the e36 on their site....thanx.!
Old 03-11-2006, 08:07 AM   #9
EuroStyle
Your Ride: 92 325i
They also have aluminum end tanks as opposed to the factory plastic end tanks... and we all know how reliable plastic BMW parts are
-Matt
Old 03-11-2006, 06:09 PM   #10
DEATH2000
DEATH2000's Avatar
Hey this thread reminds me, Harry did u have one of those radiators in ur 328i when it blew?
Old 03-11-2006, 10:24 PM   #11
komodo
komodo's Avatar
Your Ride: 1995 M3
Nah, it was a stock radiator. The plastic neck cracked though, so if I had one of these, it probably wouldn't have happened.
Old 03-11-2006, 10:33 PM   #12
Rooz
Rooz's Avatar
Rate My Car: 7 / 329
Your Ride: 2003 M5
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 03-12-2006, 07:23 PM   #13
Rob
Rate My Car: 93 / 329
Maybe it's just me, but wouldn't the AC condenser take the grunt of all the bugs and rocks and all? The only way this would happen if you deleted your AC, but I don't recommend that for a street car either.
Aluminum radiators also add higher flow capabilities to the mix. They are overall much better than anything BMW provides via OE/OEM. There is also a high performance water pump available that will create 15% or more flow through your cooling system. The water pump + the aluminum radiator = perfect cooling. Cooling has always been an issue with the E36 and so on, so this would be a perfect upgrade.
How to replace a radiator in a 540i Cambridge E12, E28, E34, E39, E60 1 12-02-2005 06:58 PM
DIY: E36 Saggy or Loose Radiator Fix. Cheap & Easy. delmarco BMW OEM Parts Department DIY's & FAQ's 0 11-09-2005 12:36 PM
radiator B3M2W5i E36 13 11-05-2005 10:18 AM
GB for Aluminum Under panel Rooz Bmw Cars For Sale/Wanted 15 09-29-2005 09:50 PM
