Old 10-31-2005, 08:15 PM   #1
BeamerGuy
Beamer problems, dude
Hey can anyone help please.
my '92 325i is misfiring real bad, and im really new to beamers, i just got one. anyway it misfires at low RPM's really bad and loses power. the power curve is very erratic. the idle is the worst, and revving it up in neutral you can really hear and feel the engine popping and missing. anyone got an idea what it is?
SamSamSam
Old 10-31-2005, 08:24 PM   #2
Rate My Car: 136 / 329
How many miles do you have on it? And do you have previous maintenance records? It can be a multitude of things - but pre 93 they are notorious for timing belt issues. T Belts are usually good for 60k but check your records if you have them.
Old 10-31-2005, 08:30 PM   #3
BeamerGuy
yeah its an old engine. 228k miles. i checked the plugs, coils, but i haven't done a compression test yet. i put all kinds of additives in the gas tank too to try to fix the problem too, but to no avail. so the T-belts go out easily? that could be it.
SamSamSam
Old 10-31-2005, 08:37 PM   #4
I'm working right now so this has to be quick. Be careful and/or try not to drive to much because if the belt goes it's going to bend some valves then it gets $$$ - i'll write more later or the others here will help you
Old 10-31-2005, 08:38 PM   #5
craig
craig's Avatar
Title: Sitting in Time out
and its bimmer, see the site name? anyway, good luck with the troubles.
Old 10-31-2005, 08:39 PM   #6
BeamerGuy
hey thanks!!! but the car has been driving quite a bit with this prob already so the damage has probably already been done. a comppression test will decide that.
SamSamSam
Old 10-31-2005, 08:42 PM   #7
BeamerGuy
what do ya mean "and its a bimmer"? of course it is, because of the site name. but what is your point?
SamSamSam
Old 10-31-2005, 08:46 PM   #8
BeamerGuy
does anyone else have an idea? one of my friends thinks its in the mass airflow sensor.
SamSamSam
Old 10-31-2005, 09:12 PM   #9
BeamerGuy
anyone have an idea?
SamSamSam
Old 10-31-2005, 09:20 PM   #10
defkon99
defkon99's Avatar
Rate My Car: 51 / 329
Your Ride: 1993 E36
Engine runs poorly or hesitates
- Check ignition system
- Check restrictions on fuek injectors
- Fuel pump output and delivery (fuels lines for restrictions) If pressure is low replace fuel pump.
Engine Lacks Power
- Tune up stats , Worn spark plugs, adjust or replace as needed.
- Air filter and intake system. Check for Restrictions or blockage.
- Check the sensor operation and wiring of fuel and ignition managment systems.
- Check throttle linkage, check to make sure it is fully opening throttle.
- Check for restricted Exhaust system?(bent or crimped exhaust pipes)
- Check for loose or defective Knock sensor( An improperly torqued or defective knock sensor will decrease spark advance and reduce power.Replace and torque to spec.
- Check for worn mechanical conditions (low compression, worn piston rings, worn valves, worn camshafts or replated parts.Rebuild or replace Engine.)
- Check engine oil level for being overfilled.
- Check intake manifold or vaccum hose leak(replace leaking gaskets, or hoses)
Old 10-31-2005, 09:25 PM   #11
defkon99
defkon99's Avatar
Your Ride: 1993 E36
try disconnecting your battery also to clear the computer who knows...
Old 10-31-2005, 09:27 PM   #12
BeamerGuy
hey thanks!!! i checked all teh easier stuff already, i think thge problem is a little more involved. im thinking i'll check that knock sensor and i'll do a compression test.
SamSamSam
Old 10-31-2005, 09:28 PM   #13
BeamerGuy
true that.
SamSamSam
Old 10-31-2005, 09:28 PM   #14
BeamerGuy
hey i'll be back in a bit
SamSamSam
Old 10-31-2005, 09:31 PM   #15
Rate My Car: 102 / 329
Also check for fault codes that may be stored. Read post #9 in this thread if you don't know how:
http://www.unitedbimmer.com/forums/s...3851#post63851
To clarify shpuz's post, Beamers (or Beemers) are motorcycles, Bimmers are cars
Got flicked off by a dude last night projal147 United Off Topic  **FOR MEMBERS ONLY** 78 02-24-2006 03:36 PM
so any common problems with the 330? Numark318i E46 6 07-03-2005 02:21 AM
Jason (dude from work) with a new e46 m3 Addicted? E46 19 04-26-2005 03:47 PM
