Old 06-12-2012, 03:43 PM   #1
Schani
Your Ride: 1994 BMW 325i
1994 325i air con/heater control panel malfunction
Hi, I own a 1994 325i, had it since new , 242,000 miles, the A/C heater control panel ( old model with temp contol knobs ), all panel switches, ie. A/C,Recirc, and rear window defrost are disabled including all led's on switches. By disconnecting battery negative cable for a minute and reconnecting the panel starts working. However this condition occours more frequently now.
Shall appreciate any advice, thanks -
Old 06-16-2012, 05:11 AM   #2
DEATH2000
DEATH2000's Avatar
Rate My Car: 111 / 340
Id recommend pulling the panel and inspecting the wiring and connections. Something is either loose, or their is an issue with the wiring.
VIEW MY E36 BLOG HERE
Old 06-16-2012, 01:00 PM   #3
Schani
thank you, will open panel and tighten connectors to climate ctrl module etc,
schani
1995 325i Need info about replacing the control arm and front end parts. Jetty E36 4 09-01-2011 01:16 AM
BMW Air Conditioning AC System 3 Minute Troubleshoot and Recharge Pictorial DIY! delmarco BMW OEM Parts Department DIY's & FAQ's 4 08-30-2011 07:11 AM
Climate control / air blower not working right !!!!!!!!!!! sams E36 11 02-21-2011 04:31 PM
Air Traffic controllers peterkdenny Comedy Collection
1 11-15-2007 08:25 AM
