Old 04-25-2005, 11:26 PM   #1
BaLAnCe17
BaLAnCe17's Avatar
Your Ride: 1998 m3 coupe :-D
my damn zkw's
hey guys so my right zkw headlight is all messed up. im talking about the adjustment. so the back adjuster, the one behind the highbeam, the back popped out and i realigned and put it back in. but my problem is....i am adjusting it downward and teh screw or whatever you call it pops out. so there is no way for me to adjust it down any further, i have to use the plastic screws to point it downward which makes it look bad. does anyone have any tips. thanx!
Old 04-26-2005, 01:41 AM   #2
BaLAnCe17
BaLAnCe17's Avatar
no one? lol its okay i guess
Old 04-26-2005, 02:01 AM   #3
bostongreen18
does it mess up the aim of your headlights? you should fix it so you arn't blinding other drivers....
if its just a mounting screw and not an aiming screw i might not worry about it.. just be sure to check the other mounting screws periodically
Old 04-26-2005, 11:53 AM   #4
BaLAnCe17
BaLAnCe17's Avatar
no, i need to adjust the mounting screw to point it down enough...the adjustment in the back keeps popping out because the way i turn it (to angle down) makes the ajustment screw pop out...i was hoping to get some feed back from some zkw owners. thanx! lol ya im trying not to blind every one
Old 04-26-2005, 04:07 PM   #5
Rooz
Rooz's Avatar
Rate My Car: 7 / 329
Your Ride: 2003 M5
call whoever you got it from....
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 04-26-2005, 06:45 PM   #6
BaLAnCe17
BaLAnCe17's Avatar
i am planning on it, i was hoping for a little input here before i gave them a call
Old 04-26-2005, 06:48 PM   #7
jrhaile
Rate My Car: 112 / 329
Sorry, I've never had to adjust my ZKW's yet. Although I need to.
http://www.geocities.com/e36rulz/test.pdf
http://www.geocities.com/e36rulz/adjust.pdf
Try reading over those to see if it helps at all.
Old 04-26-2005, 06:51 PM   #8
BaLAnCe17
BaLAnCe17's Avatar
ya, it is screw #1 in that picture. it pops out when i turn it in that direction. the problem is that the beam is not low enough and the thing pops out before i can get it any lower
Old 04-27-2005, 10:40 AM   #9
delmarco
delmarco's Avatar
Rate My Car: 224 / 329
Your Ride: 2001 330i
This happened to me....last march...I know exactly the screw you are talking about....I wounded the little screwdriver hole thing up to a point..as I was leveling it so the beam aimed downwards and then the screw in the back popped out and the aim of the projector shot upwards....
What I did was (after several troubleshoots) replace the rear screw but don't screw it in tight...and rewind the screwdriver hole thing on top to lower the light (apparantly the default aim setting on my ZKW projection, or zero position, is aimed up). Turn it really slowly....I mean slow, not medium speed. And after awhile it will adjust to the aim you want.....This should work.
Mine are aimed to the lowest.....
good luck...
Old 04-27-2005, 06:09 PM   #10
BaLAnCe17
BaLAnCe17's Avatar
but what makes me mad is....that screwing it IN would seem to me, make it go down but it doesnt, its like hanging on the last turn but it is still kinda high...so anymore tips would be sweet. thanx delmarco!!!
Old 05-02-2005, 07:07 PM   #11
BaLAnCe17
BaLAnCe17's Avatar
hey delmarco, do u have any pics of your headlights, like leveled on a wall or something? or just the light in the distance, that would help a lot!
Old 05-07-2005, 10:21 PM   #12
BaLAnCe17
BaLAnCe17's Avatar
delmarco!!??? lol
Old 05-08-2005, 01:39 AM   #13
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 72 / 329
Your Ride: 1995 M3
Haha, try PM'ing him and ask him to reply to this thread (so everyone else can see too)... maybe he just hasn't seen it though. lol
Old 05-08-2005, 01:27 PM   #14
BaLAnCe17
BaLAnCe17's Avatar
lol i did
changing bulbs in zkw's B_w. E36 3 12-31-2005 09:30 PM
the onlything bad about ZKW's BaLAnCe17 E36 9 06-19-2005 11:52 AM
ZKW's coming, hlp needed pls Rooz E36 43 06-18-2005 09:54 PM
DAMN this is tight guywithblack88e30 United Off Topic  **FOR MEMBERS ONLY** 10 05-05-2005 02:35 AM
new bulbs in the zkw's BaLAnCe17 E36 12 04-20-2005 04:19 PM
