Old 10-29-2005, 07:48 PM   #1
Rate My Car: 102 / 329
Gray skirt removal failure
Well I hope your day was better than mine. I tried removing the gray off my side skirts, to no avail. I used Greased Lightning cleaner & degreaser, same stuff as the Castrol brand, recommended by some folks over at BF.c. Saturated a small area with a napkin full of the cleaner for a 1/2 hr. . .
Then scrub the crap out of it . .
But nothing. It took off a thin layer of the gray, but no more. Plan B: go postal on it, soak the whole side for an hour . .
And wallah . . . still nothing, Now it looks worse than when I started
I dunno . . some people can't get this stuff off no matter what they do. Maybe some factory applications are more stubborn than others. Maybe I'll just get them painted along with my bumpers in the spring
Old 10-29-2005, 08:38 PM   #2
defkon99
defkon99's Avatar
Rate My Car: 51 / 329
Your Ride: 1993 E36
lmao damn you practically bleached um , and im guessing it only looks like that on 1 side?
Old 10-29-2005, 09:25 PM   #3
Orefus
paint over it
Old 10-30-2005, 12:02 AM   #4
bitcore
bitcore's Avatar
Sandpaper, then finer grit papers, then polish, then glaze, then wax.
Old 10-30-2005, 05:08 AM   #5
Originally Posted by defkon99@netscape.net
. . and im guessing it only looks like that on 1 side?
Yup Anyone have a really big Sharpie?
But never fear, there has to be some easier way to do this, and I'll figure it out sooner or later. Time for a trip to the corrosives cabinet in our shop at work
Old 10-30-2005, 05:19 AM   #6
Rate My Car: 136 / 329
"D" - if you're just getting them back to black again, try some fine grit sandpaper, wipe it with Isopropyl alcohol then mask bottom of doors and spray "rubberized rustproofing" (3M or Duplicolor) you can get them at any parts store. Just make sure it says "rubberized". Regular rustproof stays tacky and greasy. The rubberized stuff drys and is paintable
Old 10-30-2005, 05:46 AM   #7
^^^ Nah dude, all I wanna do is get the undercoating off so the skirts match the car color. Some have better luck than others when doing this I guess
(Edit): Through further research, it appears that some earlier E36's do not have body color paint under this grey. Some are pegging the models at '94 or earlier. But there appears to be not definitive concensus about this. Hmmm . . .
Old 10-30-2005, 09:43 AM   #8
Storamin
Storamin's Avatar
Title: Road Kill
my 94 had color beneath it, and my 92 had color beneath it.
just buy some real sideskirts.
Old 10-30-2005, 10:09 AM   #9
bitcore
bitcore's Avatar
Yah, the ones you have come off or rather the new ones go over it... one of the two
Old 10-30-2005, 03:42 PM   #10
Storamin
Storamin's Avatar
Title: Road Kill
i recommend this because i love the look of the m3 sideskirts. it really adds to the car.
Old 10-30-2005, 04:03 PM   #11
Spieluhr
Title: ///M Driven
From when I had my 93 I remember I had color underneath the coating. However, I don't think you can remove those side skirts, they are welded on. And I am also not so sure about adding M3 skirts either.
From what I have heard about most people trying to do this, when they got done, the paint underneath was no where near the other paint quality. Would require a lot of polishing and waxing.
as you already stated, the best and safest bet would be to get them painted when you get your bumpers done.
Old 10-30-2005, 05:04 PM   #12
jrhaile
Rate My Car: 112 / 329
for the time being, get some fusion paint and paint them... it'll look better then what you got going there. Then get them professionally painted in the spring....ORRRRR buy some M3 skirts, have them painted and installed. 300-400 at most for this entire operation.
Old 10-30-2005, 05:17 PM   #13
TJsBimm
Rate My Car: 223 / 329
Your Ride: 97 328i
Buy the stuff that turns your trim from faded back to a darker colour. Maybe Mother's Back to Black might work for the time being, might darken the gray... worth a try, cheaper for now.
Old 10-30-2005, 06:13 PM   #14
^^^ That's what I did today, and the faded look is gone, thank goodness. I like the M3 skirts but I want my jack plugs accessible. I'll just wait till spring to get everything done . . too many expenses right now. Oh well.
Old 10-30-2005, 06:29 PM   #15
TJsBimm
Your Ride: 97 328i
Glad it worked.......ya M3 skirts would be sweet!!!!!!They have jacks that are actually low enough if you've lowered your car, but if not you should be ok.
