Old 10-28-2005, 10:01 PM   #16
defkon99
defkon99's Avatar
Rate My Car: 50 / 340
Your Ride: 1993 E36
oh yea i didnt get this part :
Same pressure diff. ends. But that's my opinion
Old 10-28-2005, 10:09 PM   #17
TJsBimm
Rate My Car: 225 / 340
Your Ride: 97 328i
trying to give my honest opinion thats all, as I said all corners are going to be almost the same pressure on the cv joints(FWD or RWD)......so whether acceleration or cornering that might be the problem. Good luck noises in our cars suck@!
Old 10-28-2005, 10:18 PM   #18
defkon99
defkon99's Avatar
Your Ride: 1993 E36
damn !, so now to get the problem fixed. should i just buy some cv joints+boots and get um done anyway see if it fixes it?
anyone got a Pn and a DIY? or maybe know where they seel some good aftermarket joints ?
Old 10-28-2005, 10:26 PM   #19
bitcore
bitcore's Avatar
The final drive differential bolts are NOT a good thing to have backing out. If you have a LSD, you have to worry about this. If you have an open differential (pegleg, heh) then that is so infrequent that it isn't a concern.
Most all 325s do NOT have LSD's but it was an option. If you've ever done a burnout and had only one wheel spin isntead of both, you don't have an LSD (or your LSD clutches are worn to hell)
Check the CV's & re-seat the e-brake
To re-seat the e-brake, put the car in gear in reverse and back up, keeping the engine at about 1k rpm (just barly any throttle), then pull the e-brake firmly to re-seat the shoes. It dosn't take much, but you need to pull it up well enough to where it would stall the engine if you weren't giving it that tiny extra bit of throttle. Just 1 second's worth is good enough.
Old 10-28-2005, 10:31 PM   #20
defkon99
defkon99's Avatar
Your Ride: 1993 E36
but i dont have shoes i have Disc all around.
see the caliper in my sig
Old 10-28-2005, 10:36 PM   #21
bitcore
bitcore's Avatar
TRUST ME. If you take your rear wheel off, and then remove the disc retaining bolt, you will see shoes with a cable, spring, and bolt that clamps them to the drum portion of the disc. Unles your car didn't come with an e-brake at all, you have them.
look at this: TMS
Notice how it dosn't look like a flat frisbee? The e-brake is in that cylender that extends from the center of the rotor and clamps down on the inside of it.
edit: You sillyhead!
Old 10-28-2005, 10:59 PM   #22
defkon99
defkon99's Avatar
Your Ride: 1993 E36
ok ill try the ebrake handle @1k in reverse.
thanks guys!
Old 10-28-2005, 11:24 PM   #23
TJsBimm
Your Ride: 97 328i
Go on turner motorsports on the list is clearance, click on that and scroll down the list. There's a halfshaft(cv joint) will fit either left or right side. $149.00 US,
Old 10-29-2005, 07:00 AM   #24
Rate My Car: 106 / 340
They're referring to your e-brake (parking brake). The shoes are located inside/behind the rear disc rotors.
Old 10-29-2005, 09:06 AM   #25
defkon99
defkon99's Avatar
Your Ride: 1993 E36
yep only for e46 .
Old 10-29-2005, 10:52 AM   #26
TJsBimm
Your Ride: 97 328i
No it's says E36 91-99....325, 328
Old 10-29-2005, 03:49 PM   #27
defkon99
defkon99's Avatar
Your Ride: 1993 E36
ok thansk for link man too lazy to look , well i did the reverse thing and hit the E- brake seems to have made it gone away!
weee!
Old 10-29-2005, 04:45 PM   #28
bitcore
bitcore's Avatar
Toldya. :P
Old 10-29-2005, 06:01 PM   #29
defkon99
defkon99's Avatar
Your Ride: 1993 E36
heheh col just hope it dont startup again.
Old 10-29-2005, 11:01 PM   #30
bitcore
bitcore's Avatar
It happens frequently with my car almost anytime I use the e-brake, just whenever you ar clutching to back up for whatever raeson, tap the e-brake handle a bit. It really dosn't take much, esp. if they are adjusted properly.
The Ultimate E36 Common Faults FAQ Dudesky BMW OEM Parts Department DIY's & FAQ's 33 08-11-2012 01:00 PM
E36 Rear trailing arm bushing replacement Dudesky BMW OEM Parts Department DIY's & FAQ's 19 06-01-2011 11:02 AM
DIY: Install Rear Shades on your E36/E46/E34 BMW! delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-26-2007 10:41 AM
Sound Card Issues komodo Geek Chat 9 05-18-2005 10:11 PM
E46 Audio Information - This is a god-send. EcianIce Car Audio and Electronics 4 04-21-2005 02:22 PM
