Old 10-14-2005, 07:34 PM   #1
B3M2W5i
B3M2W5i's Avatar
belt
ok my car was hissing at me today so i took a look under the hood and one of the belts looks snapped and wrapped around my fan.. i havent changed my ac comp yet btw.. what could have caused this?
Cashmere Beige Metallic
Old 10-14-2005, 07:40 PM   #2
bmw4life
Title: Addicted BMW Freak
Rate My Car: 112 / 340
Sorry I can't help but I hope it isn't too bad
Old 10-14-2005, 07:57 PM   #3
Rate My Car: 106 / 340
They do have a life span. No pulleys misaligned?
Old 10-14-2005, 08:19 PM   #4
B3M2W5i
B3M2W5i's Avatar
ill have to check up on it 2m morining its pretty cold / foggy here
Old 10-14-2005, 09:12 PM   #5
Spieluhr
Title: ///M Driven
yeah, belts just tend to go bad every now and then.
Old 10-14-2005, 09:26 PM   #6
Rooz
Rate My Car: 5 / 340
Your Ride: 2003 M5
belts are made of flexible plastic, since there is always tension on them, after a while they go bad....
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 10-14-2005, 09:30 PM   #7
TJsBimm
Rate My Car: 225 / 340
Your Ride: 97 328i
Ya I had to do my belts after 100,000kms...they were cracked and stuff.....better off doing the belts so you don't have to go through it again.
Old 10-14-2005, 10:05 PM   #8
Rate My Car: 184 / 340
again, its not a timing belt, which is actually a good thing because otherwise youd be screwed, just order new ones, loosen the tensioner, put them on(there is a pic somewhere of how they are suppoesd to go on) and then re tighten the tensioner, peace of cake trust me
Old 10-14-2005, 10:42 PM   #9
///M Power
Rate My Car: 24 / 340
Your Ride: 95 m3 turbo
Thanks Captain, what would we do without you?
Check for alginment as someone mentioned. And then check your other belts. Probably two other belts. When one of these belts snaps in BMW's they have a tendency to take out more than one belt. Then hope you get the parts and do it yourself or hope your mechanic isnt that far.
seat belt problem jybute BMW OEM Parts Department DIY's & FAQ's 1 02-13-2006 12:24 AM
BMW Belt I will make Spieluhr United Off Topic  **FOR MEMBERS ONLY** 25 09-21-2005 04:08 AM
Help removing A/C belt projal147 E36 2 05-26-2005 04:00 PM
Timing belt? popzalock E21, E30 6 04-25-2005 12:44 PM
Fan Belt Joey E21, E30 7 04-18-2005 06:38 PM
