i am too lazy to see if i wrote belt or chain... i always write belt, though i know e36 does have a chain.
but, 7 hours? noo, only if its a noob mechanic. for a bmw mechanic that has done it a few times, should NOT take that long.. it too me a few more hours than that, and i had NO idea what i was doing... with cars... you sometimes have to just do it..... if you are determined, you can do anything
Ok, read the part I underlined carefully
Originally Posted by Rooz
well, my dad's mechanic did it for me and I helped him so I didn't pay anything...
but when I quoted it on my all data, it quotes for 7 hours of labor.... so I wouldn't do my self if I were you harry....
All data is a computerized program that gives estimates
its called all data, tis a databse for cars, has tons of info, wiring diagrams, etc etc etc, and it tells you how long it takes typically to do a job, because sometimes mechanics need it if they see a car that they have never worked with before
like for instance one of my bros audis, in order to change the thermostat, you have to take apart the timing, while a normal thermostat job is what, 15-30 mins, so if someone pulled up in that audi the mechanic wouldnt say ok it'll be done in 15-30 mins when you have to redo the whole timing
Sounds like whatever blew took out your radio maybe a surge from the alt, anyways don't take my word......I'm very curious about your situation...post...post!
I would guess it's going to be a fusible link. They're notorious for "goin'south" with moisture & age. It can be simple as one of the MANY ground leads.
Wait, huh? Can you explain that in a little more detail please.
dont feel bad.......i was kinda like that 2 weeks ago
well not really i just didnt have vac cause a hose was bad that i couldnt see..........then my car didnt start 2 days later cause the the batt only had 260 cranks
i think im good now......you will get everything fig out......
and im sure u were bumping ur shit in the drivethrough when that hap.....?
