Old 10-02-2005, 10:42 PM   #1
ivopivo
ivopivo's Avatar
Rate My Car: 140 / 340
Your Ride: 1993 BMW 325i and 2009 Yamaha R6s
help:
I don't know if this should be in E36 but i think i'll get more help here, feel free to move it if necessary.
anyway, today i noticed something on my 328i. when i turn to the right, not all the way but almost all the way, i hear a noise on the right side, mostly in front. the noise is something like when you put a screwdriver into a fan so that all the blades of the fan hit it as the fan rotates, AND something like a very very quick THUD THUD noise. that's best i can do. the noise isn't that loud but that's just to give an idea. it only happens when i turn to the right, at about 10-15mph, and nothing when i turn to the left.
i lifted the car up and took off both wheels but saw no rubbing or loose plastic which the wheel could be hitting. my guess now is some mount or somethign like that is getting old or broke, i don't know.
i'm getting it checked out asap by my mechanic but i just wanted to check if anyone here has had the same thing. thanks guys
-Ivan
LUSTR Auto Detail
"Always start with the least aggressive method!"
Old 10-02-2005, 11:46 PM   #2
Rate My Car: 184 / 340
your tie rod maybe?
Old 10-02-2005, 11:54 PM   #3
ivopivo
ivopivo's Avatar
Originally Posted by xsperf
your tie rod maybe?
sorry for the newb question but got a pic of the tierod ?
-Ivan
LUSTR Auto Detail
Old 10-03-2005, 07:22 AM   #4
Storamin
Storamin's Avatar
Title: Road Kill
check your front control arm and it's bushings.
btw, this should be in the e36 section.
Old 10-03-2005, 07:16 PM   #5
well there is the inner and the outer tie rod, my guess is it might be hitting something
Old 10-03-2005, 07:50 PM   #6
Rate My Car: 106 / 340
This is a wild guess, and completely from left field, but check your upper strut bearing?
