Old 09-20-2005, 09:29 PM   #1
B3M2W5i
B3M2W5i's Avatar
regarding a/c compressor replacement install
what would i need to cmplete the install successfully
Cashmere Beige Metallic
Old 09-21-2005, 11:38 AM   #2
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
Very good question, my ac broke so I will be doing this soon.
Old 09-21-2005, 11:45 AM   #3
zeaq328i
zeaq328i's Avatar
Title: BMW 328i
Rate My Car: 313 / 337
I did mine at the dealer.
.BMW 328
Old 09-21-2005, 03:13 PM   #4
delmarco
delmarco's Avatar
Rate My Car: 228 / 337
Your Ride: 2001 330i
I think the dealer is like $800 to $1000.
The unit alone is $500+
I've seen used ones on EBAY for less than $100.
If your A/C just needs a charge...then go to Kmart and get a $24 can of freon and find the hoses behind the positive terminal under the hood and charge it thhru there.
There is a DIY I've seen for the cheap re-charge on bimmerwerkz
Old 09-21-2005, 06:11 PM   #5
B3M2W5i
B3M2W5i's Avatar
what is the cost to get it done by a pro
Old 09-21-2005, 06:50 PM   #6
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
oh yeah I tried recharging the ac, but unfortuantely with mine it is the compressor that leaks. Some of those DIY recharge kits come with a dye that goes in it, so if you use a light, I am using a black light you can check the pipes for leaks after about a week of using it.
DIY: Install Rear Shades on your E36/E46/E34 BMW! delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-26-2007 10:41 AM
Need a little A/C help E36Bimmer E36 11 06-18-2006 02:44 PM
a/c system B3M2W5i E36 12 08-10-2005 09:31 AM
A/C question- real quick E36Bimmer E36 7 08-05-2005 07:32 AM
Brake install billycuth E36 4 05-04-2005 08:40 AM
