Your Ride: '99 328iC (E36)
Very easy to remove w/o tilt. Once you get the harness off, turn the steering wheel to RIGHT and slide the cluster out. Once out, remove the 5x torx screws from the cluster and pull off and separate into two pieces. On the front piece, rotate the three WHITE plastic ring screws and pull apart the gauges. Pop in the rings, and reassemble and you're done.
