Old 09-17-2005, 07:28 PM   #16
Storamin
Storamin's Avatar
Title: Road Kill
Originally Posted by catalyst
Heh, no, and i dont look forward to ever having to do it.
head gaskets are one of the weakest links in our engines.
you see a lot of bmws fail to complete a race and most of the times, it turns out to be a headgasket failure
personally, i wouldn't do anything that could overheat it.
as long as you used water wetter & a lower thermostat, i would say definitely do it. i wouldn't even worry about the thermostat, mostly the correct amount of water wetter really.
Old 09-17-2005, 08:30 PM   #17
///95M3
Originally Posted by komodo
It's not worth the $90 to buy a fan delete kit, however if you're in that part of the engine anyway and have everything you need, go for it. If I could go back and choose to do it again or keep my fan, I'd do the delete again. Nothing major, but it is noticeable.
60$'s for the kit and its the best mod I have bought for my car for the money HANDS DOWN. I dont know what Harry is talking about not worth it???? It's the easiest mod and you will notice a great improvement. The fact that Harry drives a Slush box shows how he shouldnt input of performance mods like this(sorry dude but you shouldnt, the detachment between driver and car on an auto is rediculous) I did drive all moded auto V8 S4s, Porsche's and our old 328i before I bought my car.
Anyway, I noticed an amazing improvement with downshifts/upshifts and it actually improved my times while autocrossing. If you drive a slush then dont bother, but if you actually drive a manual its well worth the money.
Also the only time my car ever overheated was when I was at a drift day and I was holding my car completely sideways for long periods of time. This is because I was running my rpm's between 4500-7000 rpm consistantly and no air was traveling through the front of my car.
oh and get the kit, dont just pull the fan
Current standings: 98 M3 Track car
Mods: suspension, i/e/fly only
1/4th mile: 13.7@101 on 235/40 streets
Rd Atlanta: 1:44's on RA1's, 1:46 st.trs
Past cars
95 M3 3.2obd1
540i/6
Old 09-17-2005, 09:42 PM   #18
catalyst
Rate My Car: 197 / 340
I figured that it would actually be quite noticable, its a pretty big ass fan, and it must really increase the amount of power needed to rotate the water pump.
Its been dyno proven that its a 3-4 wheel HP increase, so it really does make a difference.
What coolant mixture do you recommend storamin? 50% coolant, 2 bottles of water wetter and the rest distilled water is what i was planning.
Old 09-17-2005, 10:18 PM   #19
Spieluhr
Title: ///M Driven
bimmer world only mailed me one bottle when I did my kit, but I don't think 2 would hurt.
definately do this mod, but do it right.
Old 09-18-2005, 06:38 AM   #20
Rate My Car: 106 / 340
I threw in 1 bottle while refilling the coolant, but some of that spilled out while I was bleeding the system, so I topped off with another bottle. It's been 1 month and 700 miles since I did it, and the temp guage has been solid at just a smidge under the middle position.
As far as HP goes, it's completely negligible IME, what I did notice is that the engine is more stable at idle. On the bad side, the A/C fan turns on to the high position more often and is pretty noisy and can get annoying sometimes. Oh well . . at least I know the new switch works
Old 09-20-2005, 03:22 PM   #21
///95M3
It should be. But especially on an manual. What Harry is saying is its not, which isnt true. I was saying how he shouldnt input bec. his car is auto, which throw's off all the free revving feel you get from the kit.
Past cars
95 M3 3.2obd1
540i/6
Fan Delete Kit ? Risky MOd? defkon99 E36 51 02-18-2010 07:34 PM
Anyone done the fan delete around Redmond? STEVE36 Northwest Region 6 04-14-2007 08:27 PM
Pullies n' Fan delete ON!! ///95M3 E36 5 08-01-2005 01:58 AM
Fan Delete question ///Menace328i E36 13 07-06-2005 11:06 AM
Opinions of Fan Delete ///95M3 E36 10 06-02-2005 08:47 PM
