Old 08-25-2005, 09:11 PM   #1
defkon99
defkon99's Avatar
Rate My Car: 50 / 337
Your Ride: 1993 E36
Exclamation Dies after i turn off the Ac ? WTF!
OK so story goes.. when my Car is in park (idle) its running fine.
Now when i Turn on The AC i feel it kick in and it raises the idle just a bit ( still under 1k rpm) now when i turn off the AC the damn RPms drop wayy low and the engine dies.
Whats the deal Shitty gas? Dirty injectors? idle set too low?
any ideas would help.
Old 08-25-2005, 09:33 PM   #2
Rate My Car: 183 / 337
wow, thats a tricky one, do you have any other problems with idle? what is your idle normally at?
Old 08-25-2005, 09:43 PM   #3
defkon99
defkon99's Avatar
Your Ride: 1993 E36
like right under 1k rpm
Old 08-25-2005, 10:19 PM   #4
ok, heres another try
if you are driving normally, and you turn on the AC, do you feel a loss of power?
Old 08-25-2005, 10:22 PM   #5
defkon99
defkon99's Avatar
Your Ride: 1993 E36
yupps i feel it when the ac engages.
Old 08-26-2005, 03:08 PM   #6
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
What happens if you just hit the gas a little before it dies, does that keep it from happening. I know when I turn off my ac the revs drop a decent ammount but I have never had it die.
Old 08-26-2005, 05:54 PM   #7
defkon99
defkon99's Avatar
Your Ride: 1993 E36
yea the revs drop then it dies
( only in park)
but when im driving its fine.n
guess its just my luck
btw Nice e30.! Looks good
Old 08-26-2005, 06:28 PM   #8
your problem might be your AC is overcharged try to get a gauge and check the pressure, most likely you will have too much, just take a screwdriver or whatever and push the pin in(just like the tire) and release pressure from both the high pressure and low pressure lines
the lines will run(when looking at your engine from the front) to the left of the engine, thick hose and thin hose
Old 08-26-2005, 07:18 PM   #9
nick_318is
nick_318is's Avatar
Thanks Man
Old 08-26-2005, 07:51 PM   #10
defkon, im not sure if you hav R134A or R12, i think its R12, but with these cars all you need to do is discharge the coolant and replace with R134A, but to do that, you will need a special fitment/adapter, advanced auto parts carries it(you will need it b/c the charging kits/pressure guage will not fit on it)
Old 08-26-2005, 07:52 PM   #11
B3M2W5i
B3M2W5i's Avatar
wont you also need to change the o-rings and such since they are different chemicals?
Cashmere Beige Metallic
Old 08-26-2005, 07:53 PM   #12
B3M2W5i
B3M2W5i's Avatar
and you dont have to change to R134A people just choose to since it is now the most common i also think R12 blows cooler its just that R134A is better for the environment in case it leaks out
Old 08-26-2005, 08:23 PM   #13
defkon99
defkon99's Avatar
Your Ride: 1993 E36
no its r134a
Old 08-26-2005, 09:04 PM   #14
well then dont worry about the adapter or whatever, just make sure the pressure is right in the AC
Old 08-28-2005, 04:15 PM   #15
delmarco
delmarco's Avatar
Rate My Car: 228 / 337
Your Ride: 2001 330i
If you hear a tiny rattling sound (like odd vibrations) around the junction your alternator and belts then it's your tension idle pulley!
change it ASAP!
Engine dies enanj E46 4 01-31-2006 03:18 PM
Need help (regarding AC) - ASAP! daki77 E36 6 01-14-2006 06:30 AM
Wtf? Chris United Off Topic  **FOR MEMBERS ONLY** 7 06-19-2005 11:49 AM
