Old 08-23-2005, 03:40 PM   #1
LHerbert
Rate My Car: 179 / 329
Your Ride: 1988 BMW ///M3
Vanos Noise
How many people with VANOS have the "vanos noise"? Has anybody actually gotten it fixed? I know it's about a $1200 job and I hear it could just come back after you get it fixed. I've also heard that you shouldn't get it fixed if you don't have a problem with the engine noise because it's doing no harm and won't do anything.
Old 08-23-2005, 04:32 PM   #2
jrhaile
Rate My Car: 112 / 329
I'm not sure what noise you're referring too man...
Old 08-23-2005, 05:17 PM   #3
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
me neither... is that the metal on metal sound you get when you turn the car over?
I am worth $2,022,318 on HumanForSale.com
Old 08-23-2005, 05:24 PM   #4
Rate My Car: 173 / 329
huh? can you describe? clunk, ping.. lol, or can you atleast describe what causes the noise?
Old 08-23-2005, 06:09 PM   #5
catalyst
Rate My Car: 192 / 329
Your Ride: 1994 325is
Ive heard it sounds like marbles.. if you decide to do M3 cams or something, you mine as well change out the unit with another used one if it really bothers you that much.
Old 08-23-2005, 06:34 PM   #6
DEATH2000
DEATH2000's Avatar
Rate My Car: 123 / 329
Ive never heard a noice coming from the VANOS. My engine idles really quitley but i think i would notice. I dont think thats unless its really loud or seriously annoying its a problem.
Old 08-23-2005, 07:19 PM   #7
ahh like marbles, yes ive heard that sound before, i was checking out a car once, it was a black 525, and when you turn it on for like the first 5 seconds it sounded like marbles then it went away
Old 08-23-2005, 07:32 PM   #8
drz
Title: local dumbass
Rate My Car: 32 / 329
Your Ride: E36 2.8i
The guy who sold me my car told me that if I ever heard noise coming from the VANOS, it was time to change the oil. Sounds a little too easy.
Old 08-23-2005, 07:33 PM   #9
Rate My Car: 102 / 329
Hold on, tho. I think c4talyst has it mixed up. The marbles sound is usually associated with the catalytic converters, the vanos is usually described as a ticking noise.
Old 08-23-2005, 07:47 PM   #10
catalyst
Ive never heard it personally, i think i remember dutch having troubles with his vanos in his old 325, and he said it sounded like that.
Im assuming it makes that sound because the gears get worn down? and the cup sprocket and the sprocket on the vanos unit shake and make an odd noise.
Old 08-23-2005, 08:14 PM   #11
Hmm . . I just did some research out of curiosity, and apparently we're both right, as some describe it one way and others another.
It's also a very common issue, and from what I'm reading it's caused by poor oil circulation at the top of the engine and vanos area. To fix it permanently, you can take it to a dealer and they'll install what's called an oil accumulator to ensure that there is enough oil on top. But most people just add a little extra oil to get rid of the noise.
Old 08-23-2005, 08:55 PM   #12
bmw4life
Title: Addicted BMW Freak
Rate My Car: 111 / 329
For the first minute or so when I turn my car over it kinda sounds like marbles around the catalytic converters. So is this a real problem?
Old 08-23-2005, 10:19 PM   #13
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
hmm my car does sound weird when I first turn it on, might have to make a vid later.
Old 08-23-2005, 10:22 PM   #14
bmw4life
I think I will make a vid tomorrow
Old 08-23-2005, 11:36 PM   #15
Sometimes it's just the heat shield rattling. But if your cats are making the noise, I'd keep an eye on it. I think the worst would be the annoying noise, and sooner or later you won't pass inspection. Beyond that, there's really not much you can do but buy new cats (expensive!).
vanos noise cabrit E36 3 02-17-2006 02:25 PM
Vanos unit image daki77 E36 6 11-22-2005 09:41 PM
non vanos worth it? brien4787 E36 25 07-28-2005 09:48 PM
loose rattle noise in back Blumfepo E12, E28, E34, E39, E60 2 07-18-2005 09:05 PM
Vanos komodo E36 16 05-31-2005 09:32 PM
