Old 08-24-2005, 08:26 AM   #16
E36Bimmer
Rate My Car: 143 / 337
You can diagnose a vanos noise from others very easily.. pop the hood and manually rev the engine from the throttle body. Put your ear to the front of the engine cover and if you hear a metallic chingy sound (somewhat like marbles in a tin can) then thats your vanos making noise. You can open it up and service it, like cleaning all the built-up oil and gunk and that should help oil flow to it. Other than that BMW will replace it outright but I have heard you can just replace a $100 solenoid and that is all you need..
Old 08-24-2005, 09:38 AM   #17
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
interesting i'll have to look into that, because my car does sound a little odd when I rev it up, but I assumed it was because the engine wasn't completely warmed up, should I try this after it's warmed up?
Old 08-24-2005, 06:47 PM   #18
bmw4life
Title: Addicted BMW Freak
Rate My Car: 113 / 337
I think its my heat shield rattling but even if its my cats I don't have to do emission test so oh well. Could I fix the heat shield rattling without lifting the car up?
Old 08-25-2005, 08:16 AM   #19
E36Bimmer
sure you can if you can fit under there.. i doubt it tho.
Old 08-25-2005, 09:15 AM   #20
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
oh yeah also when you guys/girls start up your car does it go up to 2000 rpm's for a second?
Old 08-25-2005, 11:26 PM   #21
bitcore
bitcore's Avatar
http://www.pelicanparts.com/BMW/tech...aft-Timing.htm
Here's some good photos of the VANOs unit, it dosn't seem to difficult to take the valve cover off and check the sprockets and clean up some gunk.
Yah, the sticky vanos problem (dont think it causes marble noises) is just a solenoid that goes bad. Not too expensive.
vanos noise cabrit E36 3 02-17-2006 01:25 PM
Vanos unit image daki77 E36 6 11-22-2005 08:41 PM
non vanos worth it? brien4787 E36 25 07-28-2005 08:48 PM
loose rattle noise in back Blumfepo E12, E28, E34, E39, E60 2 07-18-2005 08:05 PM
Vanos komodo E36 16 05-31-2005 08:32 PM
