Old 08-21-2005, 12:44 PM   #1
defkon99
defkon99's Avatar
Rate My Car: 50 / 337
Your Ride: 1993 E36
Angry Reinstall Window Regulator ?
oK So a Previous THREAD i made about those plastic Crappy Bushings. I have now yet another problem.
the Aluminum Regulator broke at the welds and now i need the whole thing!
Im sure its an Easy fix but...... There are Pop Rivets holding the Damn thing in place . Anyone got a DIY for this ? or know where to get one.
Old 08-21-2005, 01:23 PM   #2
Rate My Car: 106 / 337
Damn . . how'd ya do that?!
PelicanParts or AutohausAz should have it.
Old 08-21-2005, 02:48 PM   #3
defkon99
defkon99's Avatar
Your Ride: 1993 E36
well i put the plastic clips on and i was raising the window but it was still going up at an angle (not right) i checked the window making sure it was ontrack after a couple tries it broke at the welds. i guess the motor put too much pressure on those welds.
im sure they will have it but im stumped on the whole rivet deal, ive never used a rivet tool.
looking for a Diy maybe somethings i gotta buy etc..
Old 08-21-2005, 05:03 PM   #4
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
Its fairly easy to do.
Take door pannel off
Lower window till you see the 8mm that holds it onto the window reg.
loosen that bolt and pull the window upto closed position
Take off the motor and unplug it
Take off 10mm that hold the regulator on and pull it out
Old 08-21-2005, 05:34 PM   #5
defkon99
defkon99's Avatar
Your Ride: 1993 E36
ok i got that but what about the rivets??
Old 08-21-2005, 05:56 PM   #6
Can you point to where you're talking about? What rivets?
Old 08-21-2005, 06:56 PM   #7
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
Are any of the ones circled in red the ones your talking about?
Old 08-21-2005, 07:17 PM   #8
defkon99
defkon99's Avatar
Your Ride: 1993 E36
Thumbs up
yea the one in the middle attached to the door thx Death2000 for that pointout
Old 08-21-2005, 08:30 PM   #9
Looks like you can drill out the holes to replace the rivets with nuts & bolts, but I'm not sure about that center pivot. And who knows if it's gonna work right again. If I were you I'd just buy a new one.
Old 08-21-2005, 08:37 PM   #10
defkon99
defkon99's Avatar
Your Ride: 1993 E36
well yea i gotta buy 1 but i dont think nuts and bolts are gonna do it.. thx 4 yur input
front window motor brien4787 E36 9 02-08-2006 11:29 PM
WTB driverside window regulator for e36 vegas mikey Bmw Cars For Sale/Wanted 10 11-10-2005 10:50 AM
Voltage Regulator? Spieluhr E36 8 10-13-2005 03:47 PM
Window Tint... what should I go with? mullethunter3 BMW General Discussion 19 08-08-2005 08:41 PM
Window Fix Sliding Pivot !!!ARGH!! defkon99 E36 19 08-05-2005 11:27 AM
