Old 08-18-2005, 01:05 PM   #1
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
Question Brake upgrades....need advice
Since i kinda need to replace my pads, i was kinda thinking of upgrading the whole setup minus the calipers. I discovered i had a bit more money than originally thought, so it may be possible for me to do in the near future.
What i plan to upgrade is obviously my pads, get slotted rotors, and definitly SS lines. Can anyone recomend a good rotor that will work with the stock calipers? If i get new rotors i would like to upgrade the calipers at some point in time, just not right away. Also if im gonna replace my rotors will a bigger than stock rotor work with my stock calipers?
Old 08-18-2005, 06:11 PM   #2
Spieluhr
Title: ///M Driven
i got the ATE power disc rotors up front, Had them on for a day with my new pads and SS lines and I notice a MAJOR difference. The set up you are talking about is definately a good one. And no, I wouldn't try getting bigger rotors for your stock calipers.
Old 08-18-2005, 06:17 PM   #3
DEATH2000
DEATH2000's Avatar
^^ Ok, thanks.
How much were the ATE rotors?
Old 08-18-2005, 07:05 PM   #4
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
I would defnitly not try bigger rotors, the ATE power discs should be very good, and help let gas escape under braking and get better cooling so you will not get brake fade, not that its an issue for just driving around, but I track my car ocasionally so its important to me.
Old 08-18-2005, 09:34 PM   #5
catalyst
Rate My Car: 197 / 337
Your Ride: 1994 325is
Just go with oem rotors, ss lines, and good pads.
With the stock calipers the difference between stock rotors and aftermarket xdrilled or w/e will be very minimal and just a waste of money. Unless your going for the bling factor..
Old 08-18-2005, 09:49 PM   #6
Rooz
Rooz's Avatar
Rate My Car: 7 / 337
Your Ride: 2003 M5
exactly what I did, But am putting "racing performance fluid" takes more heat basicly....
Once cams and manifold gets here I'll install it ALL at once...
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 08-18-2005, 09:59 PM   #7
delmarco
delmarco's Avatar
Rate My Car: 228 / 337
Your Ride: 2001 330i
regular ass OEM!!!
thats what I'm getting...
I spent even dough on labor and cosmetic upgrades and mods...
I only need brakes to work at the OEM level...and not look like I paid $2000 for some Brembo kit...
and can anyone justify $100+ for stainless steel brake lines!!!??/
WTF is up with that?
Old 08-18-2005, 10:04 PM   #8
Rooz
Rooz's Avatar
Your Ride: 2003 M5
^$126.90 actually
Old 08-18-2005, 10:12 PM   #9
delmarco
delmarco's Avatar
Originally Posted by Rooz
^$126.90 actually
Still...thats insane...
unless you are dragging you I6 at 260mph down the track daily...there is no justification for that...
I mean they would out last your rotors and pads if you were arguing longevity and quality!
i don't know...someone talk to me...
Old 08-18-2005, 10:36 PM   #10
Rooz
Rooz's Avatar
Your Ride: 2003 M5
I did it bcs I needed new lines and that was my reason to upgrade....
Old 08-19-2005, 02:30 AM   #11
Spieluhr
Title: ///M Driven
Buyers beware. I got my UUC SS lines installed and the rear hose is about half and inch too short my mechanic said. Rooz, tell me if you can get them to fit, because he couldn't, and he siad he has seen it happen many times with teh same product.
Old 08-19-2005, 04:33 PM   #12
catalyst
Delmarco, the ss lines help alot, the rubber lines that are stock on the car bulge and get bigger as you push down the pedal, hindering stopping power. With SS lines, the lines cant bulge so the flow of brake fluid is much more uniform and strong, better braking, less brake fade, and better pedal feel all come from SS lines.
IMHO these cars should have them stock.. my moms fucking s70 volvo has metal brake lines all the way to the caliper!!
Also, can you really ever have to much braking power? When you need to stop, you need to fucking stop.
Old 08-19-2005, 04:37 PM   #13
catalyst
hmm.. good info, we should look into this.. im surprised i havent heard this before though, they are a pretty popular product.
Old 08-19-2005, 04:40 PM   #14
DEATH2000
DEATH2000's Avatar
HAHAHAHA so true man. good way of puting it.
Old 08-19-2005, 04:57 PM   #15
Rooz
Rooz's Avatar
Your Ride: 2003 M5
I haven't installed mine yet, what did you end up doing?
DIY Brake Pad Change nick_318is BMW OEM Parts Department DIY's & FAQ's 6 08-25-2011 09:23 PM
E30 Brake Pad Changing Procedure nick_318is BMW OEM Parts Department DIY's & FAQ's 6 10-14-2005 05:36 PM
Advice on upgrades Longhairedhippy E46 1 09-22-2005 10:46 AM
Quality Brake Package (rotors, pads, lines) Spieluhr Vendor/Dealer Comments & Supporting Vendor Announcements 2 08-28-2005 02:05 PM
PAGIDs or MINTEX? looking for brake pads...need advice? delmarco E36 5 07-08-2005 09:43 AM
