-   -   E36 firing order (http://www.unitedbimmer.com/forums/e36/3224-e36-firing-order.html)
billycuth 08-18-2005 08:47 AM
E36 firing order
I asked about this before, and got one answer. I think it was the incorrect answer. I am trying to locate the number 5 cylinder in my engine. My Chilton manual doesn't have it, nor does my bentley CD manual (that I can find). Anyone know the precise firing order of the chambers on the s-52 engine?
I have a 1997 328i. Thanks! :drive2
xsperf 08-18-2005 09:00 AM
you mean m52? s52 is for m3, and i dont know if i sadi this before, but i assume cylnder 6 is the one all the way in the back, its CALLED cylnder 6, but it might not necessarily be the last one that fires(btw saying that, means that cylnder 5 is right before it)
komodo 08-18-2005 10:00 AM
http://www.findarticles.com/p/articl...23/ai_n6221222
says "Firing order: 1-5-3-6-2-4"
http://www.speedvisionwc.com/competi...mw-325-E36.pdf
says "Cylinder Firing Order: 1.5.3.6.2.4"
http://www.usenetcars.com/t-33667.html
says "With cylinder 1 being at the front of the car by the radiator, 1-5-3-6-2-4."
I can't find a single source to disagree with that.
billycuth 08-18-2005 11:10 AM
so it is definitely the one that is second away from the firewall? thanks guys..
xsperf 08-18-2005 02:28 PM
so, now i hate komodo and jrhaile, because i hate being wrong
*adds to enemies list*
seriously though? i thought the cylnders were 1-6, but the firing order was much different
Dudesky 08-18-2005 03:31 PM
No, it's the second one in from the front of the car . . . I was correct when you asked a few weeks ago :p
jrhaile 08-18-2005 03:40 PM
I'm on someone's enemy list... cool :)
billycuth 08-18-2005 03:50 PM
you sure dude? I am not. BMW replaced parts in cyliner 5 and it worked fine. When I replace parts in that cylinder, the misfire comes back. I am not doing something right.
E36Bimmer 08-18-2005 03:58 PM
ok here goes..from my understanding from the front of the engine leading to the back the cylinders are in order 1-2-3-4-5-6 in a straight line. The firing order is a different answer, for example according to the info: 1-5-3-6-2-4 is the firing order. So cylinder 1 first, then cylinder 5, then cyl. 3, so on and so forth...But the answer to your question is cyl. 5 is the second from the back..
94bmw325i 08-18-2005 04:00 PM
dude your cars engine seems pretty messed up if you already replaced parts of cylinder 5. Seems like all you have left is putting in an s52...
billycuth 08-18-2005 04:15 PM
haha... yeah, I'll sell THAT one to my wife... :p
xsperf 08-18-2005 04:25 PM
if the misfiring stopped,t hen it came back again, chances are another cylnder is misfiring because if the parts in 1 cylnder went bad, its just about time for all of them to go bad
and i was sayign something along the lines of e36 bimmer, cylnder #5 is the one 2 away from the firewall, but the FIRING ORDER is different, i believe when the check engine light code comes on, it numbers the cylnders by their number, not by their firing order(i remember having the same problem in a few other cars, even though they were V8's, the cylnder #'s all went in a row)
thirdly, a lot of hondas that have the distrubor wires on top, they arein a row, and on the spark plug wires you can see the 1234(referring to cylnder numbers) and they are immedietely following each other
billycuth 08-18-2005 04:48 PM
gotcha... thanks xsperf... I think I got it now.
Dudesky 08-18-2005 05:27 PM
**as I put my head up my ass**
E36Bimmer is right . . remind me never to work on my engine block.
xsperf 08-18-2005 05:53 PM
lol, ive done work on engine blocks before, timing, but id never do it to any BMW, b/c in case i might screw it up, i dont take that chance, lol
