Old 08-03-2005, 07:38 AM   #1
E36Bimmer
Rate My Car: 143 / 337
A/C question- real quick
I recently posted about A/C not being cold but freon is full. Today I troubleshooted further and noticed that the AUX fan is not turning on when the A/C is engaged. WOuld this prevent the air from being cold? Thanks
Old 08-03-2005, 11:53 AM   #2
Rate My Car: 183 / 337
yes it should, but if you are moving(i dont remember your last thread) the ac should be cold
Old 08-03-2005, 12:48 PM   #3
E36Bimmer
in motion it is still warm air... thanks tho. I'll try to get the aux fan going to see if that helps
Old 08-04-2005, 07:51 AM   #4
E36Bimmer
Update: Got the aux fan going and I figured out my problem. After going thru all the fuses I found fuse #39 was blown- the description for this fuse says air conditioner. IT was a 7.5A fuse.. I replaced it and turned the A/C on, still not cold. I check the fuse and it is blown again.. I did this twice more, once with a 10A fuse and once with a 15A fuse.. IT blew everytime. Where do i go to next to fix this prob??
Old 08-04-2005, 02:19 PM   #5
bitcore
bitcore's Avatar
Wiring short or faulty component that is causing excessive current draw - causing fuses to pop. See what is hooked onto that fuse and try to isolate the component that's causing the current draw.
It's also possible that a + wire on that fuse is shorting to the common ground.
Old 08-04-2005, 03:33 PM   #6
E36Bimmer
since the only means for this fuse is A/C, it can be any one of the A/C componets thats causing the short, correct? Im gonna tear into it this weekend to see what I find. Thanks
Old 08-04-2005, 09:49 PM   #7
brien4787
Title: DelTaco
Your Ride: e36
there is a nob in the middle of the console, but up near a vent. it can be twisted, depending on if you want warmer or cold air coming out of the vents.. make sure that is on cold hahaha
never know
Old 08-05-2005, 07:32 AM   #8
E36Bimmer
^ really? j/k.. it is set towards blue (cold). It is def the fuse issue. I was looking at the wiring diagram in the bently and it showed that fuse 39 is run to the compressor control relay so this is my culprit. Im just going to follow the red/green wire. It may be frayed or touching a ground or possibly the relay itself is shot...we'll see
quick CEL question Spieluhr E36 3 11-25-2005 12:53 AM
can someone chop me a sig real quick? Chris Video and other Multimedia 14 10-04-2005 10:51 AM
Real quick, Weird people + Race bitcore Kill Stories 3 09-06-2005 05:43 AM
Quick question.. catalyst E36 0 06-04-2005 01:26 PM
