Old 08-01-2005, 12:52 PM   #31
bimmerdame
Your Ride: 2001 325
thanks guys... your respond really helps and convinced me to put this kit too...!!!
Old 08-01-2005, 12:56 PM   #32
defkon99
defkon99's Avatar
Rate My Car: 51 / 329
Your Ride: 1993 E36
hey yea! Cheers too all on this Easy inexpensive MOD!
Old 08-01-2005, 07:24 PM   #33
Rooz
Rooz's Avatar
Rate My Car: 7 / 329
Your Ride: 2003 M5
Am probably going to do this, but I'll be doing it After cams and manifold, + by that time if there is any overheating problems you guys would have had them J/k
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 08-01-2005, 07:25 PM   #34
defkon99
defkon99's Avatar
Your Ride: 1993 E36
lol man just do the freakin mod. its cheaper than any set of cams. $60.00
Old 08-02-2005, 04:55 PM   #35
bimmerdame
Your Ride: 2001 325
as long as there's nobody here who lives in new york has this mod then I'LL definitely be the OG up in here ahahaha
Old 08-02-2005, 05:19 PM   #36
Rate My Car: 102 / 329
^^I'm across the river from you, if that counts
If you do the mod, just keep the old fan and clutch . . if you start to have problems, you can always slap it back on in like 15min.
Old 08-02-2005, 07:06 PM   #37
Izdatpaliboi
Just curious about the water wetter, does that have to be changed after a while or is that a one time deal? Thanx
Old 08-02-2005, 07:44 PM   #38
Rooz
Rooz's Avatar
Your Ride: 2003 M5
I mean, am waiting on my next paycheck to get the cams, so kinda on a limited budget. However if Chris from understeer gives me a good price for buying cams + software + FDK from him I'll get the FDK at same time.
Old 08-11-2005, 11:45 PM   #39
Okay, I just did the fan delete mod today, along with a new water pump, coolant expansion tank, upper & lower radiator hoses, and an aluminum thermostat housing. And oh yea, I changed my oil, too. What a busy day, I'm soooo beat.
Believe it or not, the hardest part was the water pump . . the new o ring was so tight, it took me a good 20min to get the pump in. Not to mention that I didn't really need to replace it, since the old one turned out to have a metal impeller. But I figured I better do it anyway. Then I broke off the engine lift bolt attached to the thermostat housing. It was so corroded it wouldn't come out, and it finally snapped. Luckily the other 3 bolts were good enough to hold the housing in without leakage. Aside from that, everything else went pretty smoothly. By the way, all the writeups I've read were correct- when that engine drain plug comes off, the coolant goes EVERYWHERE!!
On the subject of increased HP and/or torque, I don't notice it. What I do notice is the engine runs a lot smoother and more solid than with the fan on, particularly with the A/C on. So there you have it, from me at least. Anyone need a couple of buckets of old oil and coolant?
Old 08-12-2005, 06:41 AM   #40
Rooz
Rooz's Avatar
Your Ride: 2003 M5
Please tell me you did a coolant flush?
Old 08-12-2005, 07:03 AM   #41
Tochenzo
Tochenzo's Avatar
i heard it's not good with underdrive pulleys though
1998 Hellrot 328i
Old 08-12-2005, 07:11 AM   #42
But of course . . all the money I spent, I'd be an idiot if I didn't. Guess I forgot to mention that. And I didn't just drain and fill, I stuck a hose in and ran water through the entire system to get the crap completely out, then drained the system again . . the previous owner had the green stuff in there
What wasn't clear to me was how much Water Wetter to use. Chris at Understeer sends 2 bottles, but the directions on the bottle says to use 1 for most cars. I ended up using both, one while bleeding the system, which I'm sure some came out during the process, and I used the other bottle to top off when I was done.
Really? What have you heard? jrHaile has UUC pulleys with the fan delete, I wonder what his opinion on this would be.
Old 08-15-2005, 03:18 PM   #43
bimmer95
Title: village fool
Rate My Car: 24 / 329
Originally Posted by Dudesky_E36
That's why you do the fan delete, to keep kitty safe under the hood I think she was photoshop'ed in there as a joke; she's not there in the thumbnail view.
Yes, Chloe was safely napping inside the house when that picture was taken. My wife PSed her in to the picture as a joke, but managed to delete the original sans Maine Coon picture in the process, so she remains underhood as a bit of an easter egg for the site
Old 08-15-2005, 03:58 PM   #44
Spieluhr
Title: ///M Driven
I love your car. sorry for the OT, but I had to say it.
Old 08-21-2005, 10:49 AM   #45
defkon99
defkon99's Avatar
Your Ride: 1993 E36
so has anyone From UB done a DIY on this FDK Mod>? i mean im stilll trying to find a place to spew my bimmers fluids do get started, my Gf's father dont like the idea since its his driveway . which sucks... even tho i said i would use a container for the stuff.. what a butt.
Anyone done the fan delete around Redmond? STEVE36 Northwest Region 6 04-14-2007 09:27 PM
Opinions on fan delete. catalyst E36 20 09-20-2005 04:22 PM
Pullies n' Fan delete ON!! ///95M3 E36 5 08-01-2005 02:58 AM
Fan Delete question ///Menace328i E36 13 07-06-2005 12:06 PM
Opinions of Fan Delete ///95M3 E36 10 06-02-2005 09:47 PM
