Old 07-25-2005, 07:54 PM   #1
catalyst
Rate My Car: 192 / 329
Your Ride: 1994 325is
Power steering.
My steering rack started to whine this afternoon after i was fucking around in a parking lot..
I actually noticed this about a month ago, but i forgot about it because it only happens when i drive crazy and put alot of stress on the steering components, so i forgot about it.
It doesnt do it if the car hasnt been being driven nutz - ONLY happens while and after extremly fast/tight turns.
Im going to bleed the power steering fluid and put in new fluid tomorrow while i am flushing my coolant system too.. so i need to buy fluid locally - autozone/napa
Whats a good fluid to use? And some insight on how to bleed it would be great, the bentley seems to be lacking in this area.
Old 07-25-2005, 08:54 PM   #2
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
I think my haynes manual says, lemme check. Oh yeah I had a similar problem, and just added some of that power steering fluid stop leak stuff and the sounds went away.
Old 07-25-2005, 11:17 PM   #3
catalyst
If you could check that would be great.
Ive read that i need to use ATF fluid?
...anyone know?
Old 07-25-2005, 11:28 PM   #4
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
yeah I added ATF fluid, need to find my book, lemme look tomorrow..
Old 07-26-2005, 01:04 AM   #5
defkon99
defkon99's Avatar
Rate My Car: 51 / 329
Your Ride: 1993 E36
yea heres a pdf on flushing it too http://www.unofficialbmw.com/images/steering-flush.pdf
link for stuff at bottom <-- very useful info on lubricants fluids and capacities
http://www.bmwworld.com/repairs/e36.htm
Engine Oil
Type API "Certified for gasoline engines"
Viscosity SAE 10W/40 to 20W/50
Cooling System 50/50 mixture of ethylene glycol based antifreeze
Manual Transmission
Green label (1992) Gear Lubricant Special (GLS)
Red label (1992) DEXRON III Type ATF
No Label (1992) 80W GL-4
1993 or later DEXRON III Type ATF
Automatic Transmission
1992 - 1996 DEXRON III Type ATF
1997 and later Special Lubricant Fluid (SLF)
Final Drive Unit Hypoid gear oil
Braking System DOT 4 brake fluid
Power Steering DEXRON II Type ATF 1.5 quarts
Power steering leak witeshark E21, E30 15 03-10-2006 12:46 AM
Power Steering failure... Longhairedhippy E46 20 11-16-2005 10:30 PM
DIY: Add M3 steel guage rings to E36+ Remove Steering Wheel & Cluster. (pics) delmarco BMW OEM Parts Department DIY's & FAQ's 2 11-09-2005 01:05 PM
Microsoft Power Supply komodo Comedy Collection
1 07-13-2005 07:30 PM
steering wheel cruzin 323is E36 17 04-26-2005 07:18 PM
