Old 06-09-2011, 05:31 PM   #1
shmay
Your Ride: bmw 318is
Angry need help bad with water pump
Trying to get past the fan got fan blade off cant get centre piece out to get pump off
please need to use car to go to work on monday
Old 06-10-2011, 12:20 AM   #2
Manolito
Rate My Car: 337 / 337
The nut in the back of the fan clutch that screws onto the water pump is left-handed thread.
You need to make or buy a tool to hold the pulley still while you loosen it.
I bought a strap of steel from the hardware store, about an inch and a half wide and 1/8" thick and two feet long. I used the new water pump to get the distance between the bolts, and drilled two holes in the strap just big enough so the holes would fit over the 10mm bolt heads in the pulley. Then I ground a half-moon shaped notch in the side of the strap between the holes so it would fit around the pulley shaft.
With my home-made tool fitted over the 10mm bolt heads to hold the pulley from turning, I used a thin-jawed crescent wrench to loosen the big left-handed nut.
The water pump presses in to a hole and is sealed with an O-ring. It is pretty tough to break loose after 14 years, but once it starts to move you can pull it out.
While you are there, replace the thermostat and housing. Don't try to re-use the old plastic thermostat housing because it will have shrunk and warped and if you re-use it, it will leak. I use aluminum replacement housings because they are actually cheaper than plastic and they seem to work fine.
Use BMW coolant. Do not, under any circumstances, use organic acid coolant (aka Dexcool). BMW coolant is cheaper on line than from the local dealer, but it is a little late to think about that.
FS: e34 Auxilary Water Pump e39 bimmer Bmw Cars For Sale/Wanted 1 11-03-2011 12:36 PM
No voltage @ fuel pump/ Bad Ground?? reymundo10 E36 2 02-04-2009 08:33 PM
Advice on new DIY project... E30 M10 water pump mullethunter3 E36 16 12-13-2006 09:29 PM
