Old 07-22-2005, 05:53 PM   #1
brien4787
Title: DelTaco
Your Ride: e36
non vanos worth it?
I might take a look at a 325 (1992). I dont think that 92 had vanos, my question is, should i stay away? is not having vanos going to make a big difference?
Old 07-22-2005, 06:05 PM   #2
jrhaile
Rate My Car: 114 / 337
not having the vanos does suck.. it's a noticable difference in power imo. Before I bought mine, I was looking at a 92 325i and it was nothing compared to the 95 I tes drove and bought...
Old 07-22-2005, 06:18 PM   #3
DEATH2000
DEATH2000's Avatar
Rate My Car: 116 / 337
yea, jrhaile is right, vanos can make a big diff. vanos is basicly the BMW (better) version of honda's vtech.
Old 07-22-2005, 07:24 PM   #4
catalyst
Rate My Car: 197 / 337
Your Ride: 1994 325is
There are alot of plus's and minus's between the two.
Non vanos has a hotter cam, stronger valve springs and can be bored to 3.2L (or stroked)
Vanos has weaker valve springs, the cams arent as hot, and can only be bored to 3.0L (or stroked)
Ive never driven non vanos so idk how much of a difference in power there is.
Basically non vanos is better if your going to build an N/A race motor.. i doubt you will do that, so vanos would probably be a better choice.
Old 07-22-2005, 08:18 PM   #5
hamann318is
Rate My Car: 88 / 337
I'd get a non-Vanos M50 if I was going to do a motorswap.
The BMW 318 is back. With a vengeance.
Old 07-22-2005, 08:34 PM   #6
brien4787
Title: DelTaco
Your Ride: e36
Old 07-22-2005, 10:05 PM   #7
defkon99
defkon99's Avatar
Rate My Car: 50 / 337
Your Ride: 1993 E36
aye mang whats vanos?
Old 07-22-2005, 10:23 PM   #8
DEATH2000
DEATH2000's Avatar
VANOS is variable valve timing. I cnat explain it very well myself but the link brian gave has alot of info
http://forums.bimmerforums.com/forum.../t-131421.html
Old 07-22-2005, 10:33 PM   #9
defkon99
defkon99's Avatar
Your Ride: 1993 E36
so how do i know if i have Vanos?
Old 07-22-2005, 11:04 PM   #10
EuroStyle
Your Ride: 92 325i
All e36's after 92 are vanos equiped.
Old 07-22-2005, 11:13 PM   #11
defkon99
defkon99's Avatar
Your Ride: 1993 E36
so mine being a 1993 352i would have it correct?
Old 07-22-2005, 11:16 PM   #12
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 71 / 337
Your Ride: 1995 M3
Yep
Old 07-23-2005, 02:47 AM   #13
brien4787
Title: DelTaco
Your Ride: e36
on the 92.. is it supposed to have an all black steering wheel?
Old 07-23-2005, 05:26 AM   #14
Rate My Car: 106 / 337
^^Yes.
Old 07-24-2005, 09:02 AM   #15
zeit00
zeit00's Avatar
Rate My Car: 38 / 337
Hmmm.. I would say that out of the hole Vanos is better. Once you are in second gear though the power band is all wrong. I get all of my power from 3500-7000 RPM and everytime I change gears I am right back in the meat of that power band.
Vanos cars kind of lose breath after 5000 RPM.. so you shift sooner putting you at a lower RPM. The non-vanos cars where really popular on the race track. Since 1st gear is almost never used.
Also the 92 was the lightest E36 (Besides the LTW)
vanos noise cabrit E36 3 02-17-2006 01:25 PM
Vanos unit image daki77 E36 6 11-22-2005 08:41 PM
Vanos Noise LHerbert E36 20 08-25-2005 11:26 PM
worth it? B3M2W5i E36 10 08-08-2005 10:15 PM
Vanos komodo E36 16 05-31-2005 08:32 PM
