Old 07-21-2005, 09:07 AM   #1
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 68 / 340
Your Ride: 1995 M3
A/C Issues
Recently my air conditioning has been turning on and off on it's own will. I could be driving along, air condition working fine, and all of a sudden it cuts off, the led screen backlight turns off, and no buttons do anything.... basically the unit completely dies. Sometimes the green lights stay on for things like a/c on or fan placement (the vertical buttons on the left and right side)... however none of them do anything. And also when it cuts out, it usually has a gentle blowing of hot air, I'm guessing from the engine. Then I could be driving on and it might cut on for a second, off again, then on and stay on, blowing cold air and all controls working normally.
Sorry my description isn't the best, but do you guys understand what I'm faced with? Any ideas? Thanks.
Old 07-21-2005, 09:15 AM   #2
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
sounds like a short to me. probably due to one of your many elecrical wires running throughout your car now with all the gadgets...
I would take the dash apart and see if there is any exposed wire..
Old 07-21-2005, 10:00 AM   #3
komodo
komodo's Avatar
Your Ride: 1995 M3
I've already checked that, all the wiring is fine.
Old 07-21-2005, 10:15 AM   #4
billycuth
billycuth's Avatar
then your in-dash unit is probably on its way out.
Old 07-21-2005, 11:58 AM   #5
Rate My Car: 106 / 340
No, it's probably just the usual dead capacitor thing . . get you soldering iron out:
http://www.macadamizer.com/bmwfix.html
Old 07-21-2005, 12:07 PM   #6
bmw4life
Title: Addicted BMW Freak
Rate My Car: 112 / 340
Yeah I did that DIY and it has worked for over a year now. woohoo.
Old 07-21-2005, 03:00 PM   #7
drz
Title: local dumbass
Rate My Car: 34 / 340
Your Ride: E36 2.8i
Yep. Sounds like the final stage cap to me. That should fix it.
Old 07-21-2005, 03:15 PM   #8
komodo
komodo's Avatar
Your Ride: 1995 M3
How long did it take you to do it? Anything very difficult? Any advice before I try it?
Looks straight forward enough...
Old 07-21-2005, 05:32 PM   #9
bmw4life
It shouldn't take to long, probably less than an hour. I got a new capacitor but they aren't easy to find so just soder the one on their back on. It's easy to do, was just a little hard to get eveything back together.
Old 07-21-2005, 09:09 PM   #10
Spieluhr
Title: ///M Driven
same thing happened to me right after I bought my car. It is an extremely easy DIY. Go to radio shack, buy the capacitor, and soder it in. It is super super easy and will last you a long time.
Old 07-21-2005, 09:46 PM   #11
I don't know you Harry, so in case you're not handy with soldering, don't heat up the board too much or you could end up frying or loosening other adjacent components/circuits. Most of all just take your time with it
Old 07-22-2005, 12:31 AM   #12
mullethunter3
mullethunter3's Avatar
Rate My Car: 162 / 340
i don't know what you all are talkin about with the soldering, but mine was doing the exact same thing as Harry's car and there is a "secondary" blower switch thing that needs to be replaced. it's like $50 from the dealer. I just called down there, told them my problem, and it fixed it. works perfect!
Old 07-22-2005, 10:52 PM   #13
komodo
komodo's Avatar
Your Ride: 1995 M3
So today I decided to break open my a/c unit and dive in. I disassembled everything, broke free the old cap, soldered on the new cap and put it all back together. In short, it worked.
That DIY was very helpful and informative, very easy to follow with great pics.
The dealership quoted me about $400 in parts and labor to fix it. My cost was $0.49 and about half an hour of my time. The DIY says it takes 90 minutes, but it took me about 20. If you have never soldered before it might take you a bit longer.
It was a very easy fix, and basically the United Bimmer forums saved me $400. I love this place.
Old 07-23-2005, 05:01 AM   #14
Yea baby, way to stick it to the stealer
Shared knowledge is power
Old 07-24-2005, 08:37 PM   #15
defkon99
defkon99's Avatar
Rate My Car: 50 / 340
Your Ride: 1993 E36
Need a little A/C help E36Bimmer E36 11 06-18-2006 02:44 PM
price for a/c comp and sunroof parts B3M2W5i E36 12 08-25-2005 08:40 PM
a/c system B3M2W5i E36 12 08-10-2005 09:31 AM
A/C question- real quick E36Bimmer E36 7 08-05-2005 07:32 AM
Help removing A/C belt projal147 E36 2 05-26-2005 04:00 PM
