Old 07-20-2005, 01:00 PM   #1
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
Cleaning the engine
Hey guys, quick question. If I want to clean up my engine compartment, what's the best way? BMW does not recommend spraying water in there, as it can cause damage. How do you guys was yours?
Old 07-20-2005, 01:23 PM   #2
E36Bimmer
Rate My Car: 139 / 329
I use a rag and a degreasing agent. Then i'll use armor all or similar product to shine up the plastic pieces..I dont shoot water under the hood. Comes out looking great
Old 07-20-2005, 01:29 PM   #3
catalyst
Rate My Car: 192 / 329
Your Ride: 1994 325is
The best thing to do is.. tin foil over EVERYTHING electrical, and put plastic covering the firewall where the ECU sits behind, i was really careful and taped it all down.
Then take two cans of engine de-greaser (the foaming kind) and spray it EVERYWERE dont be sparing about it... i used a can and a half. Your engine bay should look like the north pole.
Then take a hose, with no fitting on the end and just let the water flow onto the engine taking all the foam with it. Oh by the way, for best results the engine should be semi hot/warm, so that all the gunk can be easily loosened up by the de greaser.
To make the black plastic peices really shine pro detailers rub WD40 onto the plastic...(valvecover, basically everything black) i wouldnt reccommend using WD40 cause it can kill your sensors. I use a product called corrosionX, its pretty expensive and hard to get, but it works well.
Old 07-20-2005, 01:46 PM   #4
DEATH2000
DEATH2000's Avatar
Rate My Car: 123 / 329
What armor all product do u use? cuase some of there stuff pretty good.
Old 07-20-2005, 03:40 PM   #5
E36Bimmer
last time I used advanced Shine armor all.. I use it on the interior as well and it does a great job of repelling dust inside.. Its been about a month since i used it last on the dash and it still has a nice deep shine to it. Good product..
Old 07-20-2005, 03:58 PM   #6
xxxbimmer
Rate My Car: 46 / 329
i used leather conditioner on all my plastic pieces the meg spray kind........its not as greasy and it has alot of conditioners in it
and it doesnt attract dust
Considering Buying An E30?Upgrades?Differences? spiff E21, E30 14 02-07-2012 11:53 PM
Alpina 318i....explain this to me delmarco E36 62 01-28-2010 04:14 AM
Engine Differences htp.bmw E21, E30 4 09-19-2007 11:34 AM
I finished the engine swap htp.bmw E21, E30 7 06-21-2005 12:33 PM
2.5l Engine, 2.8l Cams, and more for Sale jrhaile Bmw Cars For Sale/Wanted 7 04-28-2005 09:54 AM
