Old 07-18-2005, 01:16 PM   #1
pimpin328is
Brake Fluid
can anybody recommend a good brake fluid?? Should i just use what the dealerships uses or is there something better out there? Btw i have stock brakes/lines
thanks
Old 07-18-2005, 01:52 PM   #2
RealBmw 02
Title: GRIP > DRIFT
Rate My Car: 78 / 337
I use the Super Blue Racing Fluid from BMP. It has a higher boiling point that DOT4, but unlike DOT5 which is silicone, you won't have any issues with leakage. I will try to find a link for it
Edit: here is the link
Super Blue
1970 BMW 2002
Driven by skill, not money
Old 07-18-2005, 06:08 PM   #3
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
Get some of the regular stuff that the dealer uses. I believe its DOT 4 and with your stock brakes your get brake fade beore this stuff even begins to boil.
Old 07-19-2005, 01:50 PM   #4
pimpin328is
link doesn't work.....
Old 07-19-2005, 03:07 PM   #5
RealBmw 02
Title: GRIP > DRIFT
linked fixed
1970 BMW 2002
Old 07-19-2005, 05:42 PM   #6
catalyst
Rate My Car: 197 / 337
Your Ride: 1994 325is
I use super blue too.
Old 11-21-2005, 09:33 AM   #7
Rate My Car: 137 / 337
Just a "heads up" re: brake fluid - stick with DOT4 (super blue, etc) STAY AWAY from Silicone brake fluid - the only advantages of silicone brake fluid is low moisture absorbtion & if it leaks it won't remove paint (on frames, calipers, etc..) The REALLY BAD about it - it compresses to almost half it's volume in altitudes and under extreme pressure.
Old 11-21-2005, 11:24 AM   #8
94bmw325i
94bmw325i's Avatar
Title: Hellrot325
yeah I just got some of that super blue stuff, for when I get my new pads, rotors, and fluid done.
Old 11-21-2005, 04:09 PM   #9
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
I have run the Dot4 and Superblue, I currently have Superblue (it has a higher boiling point)
DIY Brake Pad Change nick_318is BMW OEM Parts Department DIY's & FAQ's 6 08-25-2011 09:23 PM
brake fluid capacity nightdevils E12, E28, E34, E39, E60 10 03-27-2007 04:08 PM
Dot 3/Dot 4 Brake fluid jms E36 8 12-31-2005 11:11 PM
Brake Fluid? Rooz E36 7 07-23-2005 08:12 PM
