deloriant how much hp do you think your car is putting out with all those mods? Those new headers sound expensive, but will prolly make your car sound even better, just need a track pipe or something.
Warning though, Hawk HPS brakes have a known squeeking problem. It can get pretty annoying.
What about the ones that UUC sells?
Originally Posted by 95bmwpwer
so know one likes my brake idea? if the brakes are done right the squeaking should not occur.. atleast with the experience i have with them
David
Well, my car is going to my dad's mechanic next week to get everything related to it's fueling system treated//repalced so I'll probably talk him into doing the ss lines too
Originally Posted by Spieluhr
I agree with the idea to go with brakes, just not your set up.
this set up that JR showed me looks about the same for a lot less.
Well, GOOD NEWS My parents said they'll pay for my tires, so that means I have mroe money to spend on the car now, I could probably do both the chip and the SS lines
Now the choice remains, Bavauto's chip or Shark injector?
shark injector. bavauto is almost an off-brand in software.... conforti shark injector has been around for way longer and installed in countless more cars without issue.
Then a little while later on, I'll tell my parents that I need new rotors (which I do, but not right away) And I'll upgrade my rotors to either cross drilled or gas slotted (dunno which is better) and as far as SS lines go, I'll probably order them soon
AHahah so this morning I was ordering new grills, and mesh plate for my m3 front bumper, and a hamman front lip, and I made the mistake of doing some more "looking" on BavAuto, saw some headers, they were all shiney and pretty and I bought them! LOL
I was looking at those too.. ( $599.95 kinda expensive...)
But check this: (From Bavauto)
Our performance headers optimize exhaust flow so your BMW can produce more power. Bavarian Autosport high performance headers are given a proprietary Sterling¨ coating. This coating allows higher exhaust gas velocity, reduces temperatures in the engine compartment and provides greater corrosion resistance than ordinary ceramic coatings. Keeps headers looking new for years and protects against thermal fatigue. Our headers are designed to bolt directly to your engine and stock or aftermarket exhaust systems. For off-road use only.
What the heck do they mean by "For off-road use only"??
I mean, do they mean that it's not street legal or what?
